January 27, 2011, 03:16 |
ANSYS and CFX not talking in two-way FSI?
Donald Brashear
Rep Power: 15 |
I get the following error when I try to update my CFX-Pre: In Analysis 'Flow Analysis 1' - Analysis Type: The specified Mechanical Input File 'ds.dat' can not be found or does not contain any valid interfaces. Specify an input file with valid interfaces, update the file location if it has moved or set the External Solver Coupling option to "ANSYS MultiField via Prep7". I started the FSI analysis by starting an ANSYS transient analysis, which I confirmed to be solvable by itself. Then I deleted the results then to "Transfer Data to New -> Fluid Flow (CFX)" from the setup. I defined my fluid-structure interface loads in ANSYS. I tried pointing manually to the 'ds.dat' file under dir\dp0\SYS\MECH\ds.dat, but the same error results. Any thoughts? Thanks |
January 31, 2011, 11:17 |
Rep Power: 21 |
In the Project Schematic delete the link between the ANSYS Setup cell and the CFX Setup cell, then re-create it and refresh CFX-Pre. That usually fixes this problem for me.
May 5, 2012, 07:32 |
Ivailo Rusev
Rep Power: 13 |
I have the same problem as brashear. I tried to delete and re-create the link between setup cells of ANSYS and CFX, but the error still exists Do you have any other suggestions? Thanks in advance Last edited by et1ap2; May 5, 2012 at 08:09. |
May 5, 2012, 10:49 |
sajad
Rep Power: 15 |
hi
i had this problem too.but i saved it in this manner and closed workbench after that i open it again and it works right. sometimes you should specify the file path yourself for the software hope to help you |
May 5, 2012, 22:17 |
Gwenael H.
Rep Power: 20 |
As Stumpy said it should work (always does for me).
If not I think you should try, >Project Directory\dp0\CFX\CFX, and use the ./ds in CFX so you have no issues when changing the project directory path. |
June 13, 2012, 05:15 |
Wei Zhao
Rep Power: 15 |
Actually it is the missing of FSIN_No# in defining the boundary of Interface of fluid and solid in CFX-re, which cause the ds.dat cannot been found or others.
November 25, 2012, 08:13 |
I met the same problem. I copied the ds.dat into the target folder from an old project and it works. I checked the contents of the file(ds.dat )and it was updated according to new project.
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! | Cirion0000 | CFX | 0 | July 6, 2009 14:26 |
FSI using Ansys LS-Dyna and CFX | YY | CFX | 2 | April 9, 2008 06:40 |
Ansys CFX 11 FSI and ICEM | Sheeko | CFX | 3 | November 16, 2006 06:42 |
MFX - for FSI between Ansys Multiphysics and CFX? | Zerocles | CFX | 1 | June 5, 2006 08:23 |
FSI using CFX and ANSYS | Bi Chang | CFX | 2 | May 10, 2005 04:47 |
