-   -   forced to sticking of soot particle (http://www.cfd-online.com/Forums/cfx/109812-forced-sticking-soot-particle.html)
kmgraju November 27, 2012 10:08
1 Attachment(s)
Dear friends
I am trying to simulate a mixture of gas and soot particles .
My idea is to trap the soot particle by suitable design of the chamber.
Please find the CCL and attached geometry . I could not find any particle movement and no sticking effect in cfx post .
Kindly rectify my mistake
Your kind help is highly appreciated
Thank you
kmgraju
LIBRARY:
MATERIAL: Air Ideal Gas
Material Description = Air Ideal Gas (constant Cp)
Material Group = Air Data, Calorically Perfect Ideal Gases
Option = Pure Substance
Thermodynamic State = Gas
PROPERTIES:
Option = General Material
EQUATION OF STATE:
Molar Mass = 28.96 [kg kmol^-1]
Option = Ideal Gas
END
SPECIFIC HEAT CAPACITY:
Option = Value
Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1]
Specific Heat Type = Constant Pressure
END
REFERENCE STATE:
Option = Specified Point
Reference Pressure = 1 [atm]
Reference Specific Enthalpy = 0. [J/kg]
Reference Specific Entropy = 0. [J/kg/K]
Reference Temperature = 25 [C]
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1]
Option = Value
END
THERMAL CONDUCTIVITY:
Option = Value
Thermal Conductivity = 2.61E-2 [W m^-1 K^-1]
END
ABSORPTION COEFFICIENT:
Absorption Coefficient = 0.01 [m^-1]
Option = Value
END
SCATTERING COEFFICIENT:
Option = Value
Scattering Coefficient = 0.0 [m^-1]
END
REFRACTIVE INDEX:
Option = Value
Refractive Index = 1.0 [m m^-1]
END
END
END
MATERIAL: Soot
Material Group = Soot
Thermodynamic State = Solid
PROPERTIES:
EQUATION OF STATE:
Density = 2000 [kg m^-3]
Molar Mass = 12 [kg kmol^-1]
Option = Value
END
REFERENCE STATE:
Option = Automatic
END
Absorption Coefficient = 0 [m^-1]
Option = Value
END
END
END
END
FLOW: Flow Analysis 1
SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s]
END
ANALYSIS TYPE:
Option = Steady State
EXTERNAL SOLVER COUPLING:
Option = None
END
END
DOMAIN: Default Domain
Coord Frame = Coord 0
Domain Type = Fluid
Location = B40
BOUNDARY: Boundary 1
Boundary Type = INLET
Location = F54.40
BOUNDARY CONDITIONS:
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Normal Speed = 10 [m s^-1]
Option = Normal Speed
END
TURBULENCE:
Option = Medium Intensity and Eddy Viscosity Ratio
END
END
FLUID: soot
MASS AND MOMENTUM:
END
PARTICLE MASS FLOW RATE:
Mass Flow Rate = 0.8 [kg s^-1]
END
PARTICLE POSITION:
Option = Uniform Injection
NUMBER OF POSITIONS:
Number = 2000
Option = Direct Specification
END
END
END
END
END
BOUNDARY: out
Boundary Type = OUTLET
Location = F48.40
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Average Static Pressure
Pressure Profile Blend = 0.05
Relative Pressure = 0 [Pa]
END
PRESSURE AVERAGING:
Option = Average Over Whole Outlet
END
END
END
BOUNDARY: wall
Boundary Type = WALL
Location = \
F41.40,F42.40,F43.40,F44.40,F45.40,F46.40,F47.40,F 49.40,F50.40,F51.40\
,F52.40,F53.40
MASS AND MOMENTUM:
Option = No Slip Wall
END
WALL ROUGHNESS:
Option = Rough Wall
Sand Grain Roughness Height = 0.2 [mm]
END
END
FLUID: soot
PARTICLE WALL INTERACTION:
Option = Equation Dependent
END
VELOCITY:
Option = Restitution Coefficient
Parallel Coefficient of Restitution = 1.0
Perpendicular Coefficient of Restitution = 0.3131
END
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
Option = Non Buoyant
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
FLUID DEFINITION: Air
Material = Air Ideal Gas
Option = Material Library
MORPHOLOGY:
Option = Continuous Fluid
END
END
FLUID DEFINITION: soot
Material = Soot
MORPHOLOGY:
Option = Dispersed Particle Transport Solid
PARTICLE DIAMETER CHANGE:
Option = Mass Equivalent
END
PARTICLE DIAMETER DISTRIBUTION:
Diameter = 1e-10 [m]
Option = Specified Diameter
END
PARTICLE SHAPE FACTORS:
Cross Sectional Area Factor = 1.0
END
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
FLUID: soot
EROSION MODEL:
Option = None
END
PARTICLE ROUGH WALL MODEL:
Option = None
END
END
HEAT TRANSFER MODEL:
Fluid Temperature = 300 [C]
Option = Isothermal
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = k epsilon
END
TURBULENT WALL FUNCTIONS:
Option = Scalable
END
END
FLUID PAIR: Air | soot
Particle Coupling = One-way Coupling
MOMENTUM TRANSFER:
DRAG FORCE:
Option = Schiller Naumann
END
PRESSURE GRADIENT FORCE:
Option = None
END
TURBULENT DISPERSION FORCE:
Option = None
END
VIRTUAL MASS FORCE:
Option = None
END
END
END
END
INITIALISATION:
Option = Automatic
INITIAL CONDITIONS:
Velocity Type = Cartesian
CARTESIAN VELOCITY COMPONENTS:
Option = Automatic
END
STATIC PRESSURE:
Option = Automatic
END
TURBULENCE INITIAL CONDITIONS:
END
END
END
OUTPUT CONTROL:
RESULTS:
File Compression Level = Default
Option = Standard
END
END
SOLVER CONTROL:
Turbulence Numerics = First Order
ADVECTION SCHEME:
Option = High Resolution
END
CONVERGENCE CONTROL:
Length Scale Option = Conservative
Maximum Number of Iterations = 100
Minimum Number of Iterations = 1
Timescale Control = Auto Timescale
Timescale Factor = 1.0
END
CONVERGENCE CRITERIA:
Residual Target = 1.E-4
Residual Type = RMS
END
DYNAMIC MODEL CONTROL:
Global Dynamic Model Control = On
END
PARTICLE CONTROL:
PARTICLE INTEGRATION:
Option = Forward Euler
END
END
END
END
COMMAND FILE:
Version = 14.0
Results Version = 14.0
END
SIMULATION CONTROL:
EXECUTION CONTROL:
EXECUTABLE SELECTION:
Double Precision = Off
END
INTERPOLATOR STEP CONTROL:
Runtime Priority = Standard
MEMORY CONTROL:
Memory Allocation Factor = 1.0
END
END
PARALLEL HOST LIBRARY:
HOST DEFINITION: mechfran
Host Architecture String = winnt-amd64
Installation Root = C:\Program Files\ANSYS Inc\v%v\CFX
END
END
PARTITIONER STEP CONTROL:
Multidomain Option = Independent Partitioning
Use Large Problem Partitioner = Off
END
MEMORY CONTROL:
END
PARTITIONING TYPE:
MeTiS Type = k-way
Option = MeTiS
Partition Size Rule = Automatic
END
END
RUN DEFINITION:
Run Mode = Full
Solver Input File = Fluid Flow CFX_001.res
END
SOLVER STEP CONTROL:
MEMORY CONTROL:
END
PARALLEL ENVIRONMENT:
Number of Processes = 1
Start Method = Serial
END
END
END
END
