FSI Wall Expansion Problem
Old   April 18, 2012, 20:56
Question FSI Wall Expansion Problem
Ashkan Javadzadegan
ashtonJ is on a distinguished road
Dear All,
I did steady FSI in a straight pipe with 50pa inlet pressure and 0 outlet pressure. Someone else for his thesis did the same simulation few years ago, there is a big difference between my results and his results. For me, the pipe wall is expanded close to inlet and outlet, however, for him, the wall is expanded in the middle of the pipe. Does anybody know where the problem originates from.
An image regarding this issue is attached.
http://imageshack.us/photo/my-images/217/fsi1.jpg/
Kind regards,
AshtonJ
ashtonJ is offline   Reply With Quote
Old   April 19, 2012, 00:45
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Dear Ashkan,
How did you create your geometry, and can you be more specific about your problem setup. If you have the exact same setup you should find the same, from your image I suppose that your BC aren't well imposed.
I'm investigating the static instability of your pipe conveying fluid using Ansys 14, if your setup is done properly you can have some results like buckling.
Gweher is offline   Reply With Quote
Old   April 19, 2012, 01:04
Ashkan Javadzadegan
Dear Gweher,
Thanks for your reply. Let me explain my problem.
I am doing steady FSI in a simple straight pipe.
Pipe length: 8cm
Diameter: 2cm
Wall thickness: 0.1cm
The material of the wall is:
Young module: 10MPa
Poisson ratio: 0.3
Density: 1050 kg/m^3
Structural setting
Hex dominant (Quad) mesh with 1188 Elements
Analysis Settings:
Autotime stepping: Off
Define by: substeps
Number of substeps: 1
Time Integration: Off
Boundary Conditions:
Inlet and outlet: Fixed support
Inner surface of the wall: Fluid-solid interface
Fluid setting
Hex dominant (Quad) mesh with 8800 Elements
Inlet: Static Pressure 50Pa
Outlet: Static Pressure 0Pa
Wall: fluid-solid interface
Initial conditions:
Automatic
Solver Control:
Fluid part:
Advection scheme: High resolution
transient scheme :Second order backward
max loops: 100
convergence criteria:0.0001
Structural part:
max iteration: 25
Under relaxation factor: 0.75
Convergence target: 0.01
I went through all the thesis settings and am sure that I used the same settings.
Kind regards,
AshtonJ
Old   April 19, 2012, 03:36
Gweher's Avatar
Gwenael H.
When you imposed your boundary condition (Structural) did you select the inner radius edge, the outer edge or the surface thickness?
If you send me your files I can have a quick look.
Old   April 19, 2012, 04:43
Ashkan Javadzadegan
Thank you very much for your kind attention.
Can I have your email address plz to send my case. I am in the Uni and here I don't have access to the file sharing website like Rapishare.
Kind regards,
AshtonJ
Old   April 19, 2012, 07:14
Gweher's Avatar
Gwenael H.
I've send you an e-mail, I'll try to have a look tomorrow.
Old   April 19, 2012, 08:04
Ashkan Javadzadegan
Thank you very much. The file is sent.
Kind regards,
AshtonJ
Old   November 26, 2012, 09:12
PrabjibKb
kok2945 is on a distinguished road
Hi Ashkan, I am also working a very similar geometry as yours by using ANSYS CFX V12 solver. I was wondering if you have figured out how to solve the boundary conditions that you mentioned here? Or, was that the boundary issues that caused your mesh deformation different than the one simulated by the author?
Thank you.
kok2945 is offline   Reply With Quote
Old   December 5, 2012, 07:07
Govindaraju
kmgraju is on a distinguished road
Dear friend
I am working on similar problem . I am doing transient two fsi problem.
I don't know how to do Analysis settings in the transient structural
Kindly help me to figure out time step , number of steps etc
Regards
Govind
kmgraju is offline   Reply With Quote
Old   December 5, 2012, 07:18
Govindaraju
Dear friend
I confuse with step control settings. Is it necessary for pulsatile flow through the pipe?
Regards
Govind
Old   December 5, 2012, 13:19
PrabjibKb
Originally Posted by kmgraju View Post
Dear friend
Regards
Govind
I Govind, for the structural part, ANSYS CFX Tutorial - Chap.23 for FSI may give you some idea how to set it up. For my case, the only change I made was instead of using timestep, i used Substeps. and no. of substep=1. I hope this helps. May i know what is your topic about?
RPI Wall Boiling Problem aliemadi CFX 4 September 1, 2018 21:14
Deforming wall problem alxasli FLUENT 3 January 10, 2011 06:22
Wall formation problem in 3D geometry subha_meter Main CFD Forum 0 July 23, 2010 03:46
Problem Interface Solid Fluid with wall velocity Solver v12 hills1 CFX 2 October 12, 2009 05:36
Wall function problem in Fluent mefpz FLUENT 1 October 10, 2007 13:43
