Home > Forums > CFX
CFX Post: Vector notation
Old   December 7, 2012, 04:54
Default CFX Post: Vector notation
S.Bogoda
sakurabogoda is on a distinguished road
Dear All,
I am using CFX14 for cyclone model. This problem relates to CFX Post Processing.
My problem is I know how to get variables of Axial, circumferential and radial velocities.
The problem is I can get contours of these variables, but I cannot get them in vector notation. In vector plot, it shows only the velocity in the selection box.
Can anybody help me to fix this matter?
Thank you.
sakurabogoda is offline   Reply With Quote
Old   December 8, 2012, 05:51
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
If you want the vector quantity then why isn't the velocity vectors in the absolute frame of reference adequate?
You might have to define a new variable as a vector quantity, and manually set the vector components.
Old   December 8, 2012, 06:24
S.Bogoda
Dear Glenn,
Thanks a lot for the reply.
But actually I cannot understand what you mean by
"If you want the vector quantity then why isn't the velocity vectors in the absolute frame of reference adequate?"
Could you please clarify?
I used Turbo to initiate axis of rotation and calculate the velocity components. But these calculated velocity components are not showed in vector notation.
My requirement is to plot axial, tangential and radial velocities on a plane.
Old   December 9, 2012, 05:44
You do not need a vector quantity to plot axial, tangential and radial velocities on a plane. It appears you already have this as scalar quantities, so can you just plot those on a plane? You need 3D quantities when doing 3D operations like vectors and streamlines, and most of these operations can be done just as well using the default Velocity variable (ie in the default cartesian coordinates).
Old   December 10, 2012, 23:20
S.Bogoda
Thank you very much for the reply Glenn.
I think I have misunderstood something.
Do you mean that I can plot them on a plane directly? I know to plot quantities on a plane by using vector or contour form only.
I could plot them by using contours, but my requirement is to plot them as vectors independently.
When I used contours it appeared in the selection variable box (image 1) but not in vector selection box (image 2).
Old   December 11, 2012, 04:59
Can you explain what you want to do? I do not understand what you are trying to show.
Old   December 11, 2012, 05:35
S.Bogoda
I want to draw Radial velocity of a cyclone flow on a cross sectional plane. I have seen it before on a research paper which been done in FLUENT.
The previous attachments show that, when plot a contour on the plane, Radial velocity is showed in the selection box(in image 1), but it is not in the selection variable box, when plotting vector (image 2).
Simply, I want to plot Radial velocity as a vector form.
Really appreciate your kind helps.
Old   December 11, 2012, 17:55
Can you post an image of what you want to do? The image from the research paper would be good.
Thread Tools
Trackbacks are On
CFX post legend modification mactech001 CFX 3 December 25, 2011 23:12
How to get reynolds stress values in POST CFX syler3321 CFX 5 March 17, 2011 01:23
CFX post - graph kmgraju CFX 0 July 22, 2010 11:59
Chart Generation in CFX Post Vadim Baines-Jones CFX 2 August 28, 2007 09:14
Tecplot for CFX post processing pantangi goud CFX 2 August 24, 2005 16:42
