December 19, 2012, 06:55 |
Profile input to CFX in Turbomachines
mistry
Rep Power: 17 |
Dear friends,
I have total pressure profile (along the span)at inlet of axial flow compressor. this i want to use as a inlet condition and static pressure as outlet. I tried a syntax given for velocity x,y,z,u,v,w by changing x,y,z,Po but this profile is not been considered by CFX. guide me for the same. Thanks |
December 19, 2012, 11:54 |
Bruno
Rep Power: 21 |
Instead of Po, try naming it 'Total Pressure' or 'pt'. CFX only auto-completes the fields when it detects a known name.
If it doesn't, there's two things you can do: 1 - Double click the BC Profile you imported. You'll see there's a field in it to link it to a known CFX variable. Choose 'Total Pressure' (or 'Total Pressure in Stn Frame') there and see if the auto-complete now works. 2 - If it doesn't, just enter the data manually. It should be something like: <profilename>.<columnname>(x,y,z) where <profilename> is the name of the profile you imported (usually the filename) and <columnname> in you case seems to be Po. Cheers |
December 19, 2012, 13:13 |
mistry
Rep Power: 17 |
Thanks for your reply.
I have single line data (along span) for total pressure at the inlet. i had written the profile as x,y,z,pt This is accepting by checking user function with basic settings x,y,z, pt For boundary details it shows no option (as can be seen if we insert velocity components automatically). instead it selects Stat. frame. tot. press. as we consider for total pressure inlet as single value. even in plot option it selects the relative pressure!!! suggest me best guide line for the same.. Thanks |
Display Modes | |
Womersley profile in CFX 11 | Chris Basciano | CFX | 25 | January 5, 2019 05:28 |
[ICEM] Node Number vs. Node_ID & ICEM vs. CFX | Araz | ANSYS Meshing & Geometry | 1 | April 25, 2011 11:03 |
Determine Thermal streeses by CFX module | Riken | CFX | 3 | August 3, 2008 20:58 |
Importing solutions in CFX. | Alphonso | CFX | 1 | August 1, 2008 14:01 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
