Remeshing with ICEM scripting
Here is my problem. I'm trying to do simulation in CFX where considerably large displacements are taking place. Basically I'm moving a slider in a valve. I thought that it may be a good idea to use scripts in ICEM to make a meshing. I'd like to start with simulating 2.5D problem. I think that the best idea is to use hexa meshing via blocking function. So it's not a problem to make a blocking on this relatively simple geometry, but how to make another and automatic blocking using scripts in ICEM when solver face interruption condition ? Secondly, I've tried to make a tetra meshing but geometry is replacing to the starting point during remeshing, even though the plot of the displacement is showing constant progress in one direction. Thank you in advance. |
I've found a solution to the replacing geometry problem while remeshing. It's important to use correct parameters when defining the time and displacement of the simulation.
