-   -   Modeling a cross flow in a staggered tube bundle using ANSYS CFX (http://www.cfd-online.com/Forums/cfx/110633-modeling-cross-flow-staggered-tube-bundle-using-ansys-cfx.html)
ashraf88 December 16, 2012 11:42
Hi every one,
Task: Modeling a cross flow in a staggered tube bundle using ANSYS CFX.
Given: The fluid is water of 300 deg Clausius flowing with inlet velocity 1 m/s,the boundary conditions are defined very well.
Problem: The results shows that water temperature is not changing along the domain; water temp. inlet same as outlet.
So I am not sure about the reason of that, Turbulence model, or water velocity, Heat transfer mode ( Total energy or Thermal Energy) ?
Please help me .
ghorrocks December 16, 2012 17:29
First of all, please do not hijack threads. Start a new thread for a new question - especially when your question is not related to the original thread.
This problem could be caused by many things - it could be inaccuracy in your simulation (see http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F for tips) or it could be that the setup you are modelling does not result in significant heat being transferred to the water. From the sketchy details you have posted I cannot tell.
Also - are you sure you are using a thermal model? You would not get any heat transfer if you have not enabled thermal modelling. Also how have you modelled the tube bank?
ashraf88 December 16, 2012 22:21
Dear ghorrocks,
I really appreciate your replay, I am so sorry that i didn't started a new thread.
I am sure that I am using the thermal modeling. But what I am not sure about is that may be I didn't make the setup well.
The tube bank is modeled as a cylinders, not Conjugate heat transfer
Thanks so much for your kind response
ghorrocks December 16, 2012 22:27
Can you post an image? Also your CCL would help.
