Home > Forums > CFX
cfx nanofluid
Like Tree2Likes
  • 2 Post By ghorrocks
Old   December 20, 2012, 17:15
Default cfx nanofluid
bitak
bitak is on a distinguished road
Hello.
How I can simulate nano fluid ( fluid + nano particle) in CFX?
I should use particle transport model or dispersed solid model?
if I use lagrangian model, I should solve my case unsteady?
thanks...
bitak is offline   Reply With Quote
Old   December 21, 2012, 11:35
Chris DeGroot
cdegroot is on a distinguished road
How many particles do you want to model? I am guessing if they are nano particles, it is a lot? Lagrangian gets more expensive with large numbers of particles. In the Modelling Guide there are tables with the advantages and disadvantages of each. You should weigh these factors when deciding which model to use.
In terms of running steady or unsteady, that depends on if your problem is steady or unsteady, although sometimes time-stepping to a steady-state solution can improve convergence for tough multiphase problems.
cdegroot is offline   Reply With Quote
Old   December 21, 2012, 13:08
bitak
number of particles are 100.
Old   December 21, 2012, 13:09
Chris DeGroot
I would use Lagrangian then.
Old   December 22, 2012, 08:18
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
Whoa there, not so fast.
We should put a FAQ up for nanoparticles, it has been asked quite a bit recently....
What physics is acting on the nanoparticles? The whole thing about nanoparticles is they do not have viscous drag acting on them, instead they have Brownian motion and possibly other forces which are usually ignored for multiphase simulations. So Lagrangian particle tracking is in general NOT suitable for nanoparticles as Lagrangian particle assume viscous drag. So unless you want to define your own particle force routine to put the correct forces on the particles, the approach I generally recommend is to use a passive scalar with diffusivity. The diffusivity can be used as a simple analog for Brownian motion.
Bitak: What is the important physics acting on the particles? That will help decide what approach is best.
Far and amin_gls like this.
Old   December 22, 2012, 09:38
Chris DeGroot
Very interesting Glenn. I was not aware of the special physics behind nano particles.
Old   December 23, 2012, 05:37
It all comes from CFX being a Navier Stokes solver and that assumes a continuum. Somewhere in the range from micro to nano scale flows (1e-6 to 1e-9 metres) the continuum assumption becomes inaccurate and atomic level stuff starts becoming important. Ideally you should use a molecular kinetics solver for nano scale stuff, but depending on exactly what you are doing you might be able to get away with a NS solver like CFX.
That is why I asked for futher details - whether CFX can do it depends on what is to be modelled.
Old   December 23, 2012, 14:55
bitak
Thanks all.
I want to simulate ferrofluid ( nanoparticles have 10^-9 m diameter) in the tube (5 mm dimeter) and apply a magnetic fieild on this flow.
my governing equations are navier stokes.
I have no slip flow in my domain.
I don't know I should simulate traansient or steady my problem?
and which model in multiphase flow is useful for my problem and also is accurate?
particle transport? or solid disperssion?
Thanks...
Old   December 23, 2012, 16:02
Chris DeGroot
I think Glenn has already answered most of these questions for you. In terms of steady or unsteady that depends what you are trying to model. Are you seeking a steady state solution or are you interested in observing something that changes with time?
Old   December 23, 2012, 17:26
CFX can model the water bit easily. But dealing with the nanoparticles is a bit trickier. If you use a lagrangian particle tracking approach you are going to have to do something so Brownian motion can be modelled - although if you only have 100 particles the "random walk" approach sounds more appropriate. Tuning this so that it matches the true diffusion due to Brownian motion will be tricky. Adding a body force to the particles for the magentic field is relatively easy.
Alternately if you take the additional variable approach the diffusion is easy, but adding the magnetic body force to it will require some thought.
Can I ask why do you care about 100 particles of diameter 1e-9m in a tube of water? There are going to be far more particles bigger than that just from contamination and shed off the tube wall and other sources. What makes the iron particles so important?
Thread Tools
Trackbacks are On
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 10 December 11, 2015 20:52
High Resolution (CFX) vs 2nd Order Upwind (Fluent) gravis ANSYS 3 March 24, 2011 03:43
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 13:22
PhD using CFX Rui CFX 9 May 28, 2007 05:59
FSI using CFX and ANSYS Bi Chang CFX 2 May 10, 2005 04:47
