Ansys Workbench mesh generation
Hi to every one,
In fact I am trying to simulate a FSI problem in Ansys Workbench. For mesh generation of solid and fluid the Workbench uses ICEM software but I want to use CFX mesh generation software, how can I solve this problem ? sincerely |
Hi
do you mean you want to work with workbench? it has two parts design modeler and cfx mesh. you can do it easily by workbench. |
Hi Mrs. Zandi and thanks for your reply,
In fact I want to use use work bench with CFX mesh generation but unfortunately ICEM mesh generation always loads NOT CFX mesh generation. sincerely |
hi workbench and icem-cfd are two independent parts which are located in ANSYS sofware pack. I did not use icem-cfd and just have a friend worked on it. I have used workbench for meshing. it has cfx-mesh.
Thank you for your reply.
ANSYS CFX isn't able to remesh a geometry by its own (Fluent does). As was mentioned you can use either ICEM CFD, or ANSYS Meshing. If you want to use ANSYS Meshing for remeshing process definitely take a look at the following tutorial (http://www.edr.no/blogg/ansys_blogge...nch_cfx_remesh).
| All times are GMT -4. The time now is 00:11. |
