Home > Forums > CFX
Volume patch
Old   December 31, 2012, 13:09
Default Volume patch
Prateek
Prateek garg is on a distinguished road
I have one doubt, I wish smeone can help on this.
As i told you am trying to model detonation and I am done with mixing of tube with fluid, now I want to use these results (.res) as input file for next step i.e. ignition. For ignition I am using a small volume patched with high temperature and pressure (5 atm and 2000K )and another bigger volume i.e rest of the tube with 300K and 1 atm. but the problem is after i start the run i saw that volume is not patched with HIGH temp and pressure (as I check at 0 time step). I am thinking that its taking the value of temperature and pressure from results file, but then in that case How can i patch this domain?? What could be the possible reason??
Prateek garg is offline   Reply With Quote
Thread Tools
Trackbacks are On
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Native Meshers: blockMesh 2 March 14, 2012 10:56
StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
Import gmsh msh to Foam adorean Open Source Meshers: Gmsh, Netgen, CGNS, ... 24 April 27, 2005 08:19
UDF for ellipse shape volume patch in VOF model nazeem FLUENT 1 October 8, 2004 11:22
