Home > Forums > CFX
Grade efficiency curves in CFX
Old   January 8, 2013, 09:44
Default Grade efficiency curves in CFX
S.Bogoda
sakurabogoda is on a distinguished road
Dear All,
I want to obtain grade efficiency curves at inlet and outlet of my domain. Can anybody help me?
I am using LES for Lagrangian particle tracking.
I would be much grateful for your helps as I stuck on finding collection efficiency of my simulation.
sakurabogoda is offline   Reply With Quote
Old   January 8, 2013, 18:18
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
What is a grade efficiency curve?
Old   January 8, 2013, 22:13
S.Bogoda
Dear Glenn,
“When we obtain particle collection efficiency of a poly dispersed sample, there is a range of particle sizes, separate with varying degrees of efficiency. This variation in the efficiency is referred to as the Grade Efficiency Curve”.
In my simulation I have to obtain this grade efficiency curve.
Actually, still I could not find how to obtain the collection efficiency in particle tracking. I found User FORTRAN can use for this one, but stuck on this stage.
Do you have any idea on obtaining collection efficiency and grade efficiency curves?
I am really tired of this. Many thanks for your helps.
Old   January 9, 2013, 05:45
The solver should report particle fates by size group - it will tell you how many go out the outlet and how many got trapped. This sounds like what you need for a grade efficiency curve calculation.
Old   January 9, 2013, 09:27
S.Bogoda
Dear Glenn,
Thanks a lot for the reply.
I have done a simulations in CFX-tutorial to understand particle flow and to find particle mass fractions @ inlet and outlet. (All were steady state simulations)
I found in output file, it gives only the mass fraction @ inlet and outlet.
For example, in the tutorial "11. Flow through a Butterfly Valve" Particle diagnostics as follows,
Particle Diagnostics
| Particle Mass Flow Summary |
Sand One Way Coupled
Inlet 1.0000E-02
Outlet -1.0000E-02
Sand Fully Coupled
Inlet 1.0000E-02
Outlet -1.0000E-02
| Particle Momentum Flow Summary |
Sand One Way Coupled X-Comp. Y-Comp. Z-Comp.
Inlet 0.0000E+00 0.0000E+00 4.1087E-02
Outlet 4.4985E-04 -1.9144E-03 -4.1069E-02
Sand Fully Coupled X-Comp. Y-Comp. Z-Comp.
Inlet 0.0000E+00 0.0000E+00 4.0947E-02
Outlet 1.0488E-03 -4.4581E-03 -4.0543E-02
| Particle Forces on Walls |
Default Domain Default -1.1786E-04 -3.2385E-03 3.0524E-03
pipe wall -1.4197E-02 -3.0213E-03 3.1836E-04
Default Domain Default -5.2943E-05 -4.0915E-03 3.7797E-03
pipe wall -1.2482E-02 -2.6480E-03 2.6313E-04
But in this tutorial it used poly dispersed sample, and only "mass flow" is given in output, no mass/diameter fractions.
I know in this tutorial, all particles should be escape from outlet. My simulation is a cyclone separator (by LES) and still I haven't done simulation on that. Because I am thinking about how to view inlet and outlet grade efficiency considering these tutorial examples.
Really appreciate your advises.
Old   January 12, 2013, 16:23
Have a look at the documentation, for particle diagnostics. I think you have to enable this in the output tab in CFX-Pre.
Thread Tools
Trackbacks are On
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 14 June 15, 2016 09:36
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 13:22
Different flow pattern between OpenFOAM and CFX AirS OpenFOAM 0 January 12, 2010 08:08
heat generation in CFX Ema CFX 4 August 7, 2009 05:39
FSI using CFX and ANSYS Bi Chang CFX 2 May 10, 2005 04:47
