How to fix this?
1 Attachment(s)
i has a error: An error has occurred in cfx5solve no results has been created.
+--------------------------------------------------------------------+ | Writing transient file 0_CS.trn | | Name : Transient Results 1 | | Type : Selected Variables | | Option : Every Coupling Step | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #002100061 has occurred in subroutine SERVE_CLIENTS. | | Message: | | The connection between this CFX process and an external process | | has died unexpectedly. The following error was received: | | External process : ANSYS | | Error experienced : Read | | | | ** This error is fatal: Terminating ANSYS CFX Solver execution ** | | Please review the output, error and log files from both the CFX | | and external processes to determine the cause of the error. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. +--------------------------------------------------------------------+ | The following transient and backup files written by the ANSYS CFX | | solver have been saved in the directory | | C:/Users/Admin/AppData/Local/Temp/nhe | | 210_4732_Working/dp0/CFX-1/CFX/Work2/Fluid Flow CFX_002: | | | | 0_CS.trn | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | The results from this run of the ANSYS solver have been written to | | C:\Users\Admin\AppData\Local\Temp\nhe | | 210_4732_Working\dp0\CFX-1\CFX\Work2\Fluid Flow CFX_002.ansys | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | The following user files have been saved in the directory | | C:/Users/Admin/AppData/Local/Temp/nhe | | 210_4732_Working/dp0/CFX-1/CFX/Work2/Fluid Flow CFX_002: | | | | mon | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Warning! | | | | After waiting for 60 seconds, 1 solver manager process(es) appear | | not to have noticed that this run has ended. You may get errors | | removing some files if they are still open in the solver manager help me, thank you very much! |
