Exporting values
Hello sir,
For transient analysis i have a different time step backup files i plotted time V/S Temperature using CFX POST plot option now i want to export these values to microsoft excel.i checked options in table viewer also but there is no such option(i attached plotted graph)https://lh6.googleusercontent.com/-u...-k/Capture.JPG Thank You |
Right click on the monitor window, export.
exporting data
Hello sir,
Thank you for your reply i want to export data in CFX_post from chart viewer( plotted graph) not from solver monitor how to export it to MS excel. Thank you |
If you want to export the values along an object that is easy, just use file/export. Not sure about exporting over time at a point. You might have to use a script to do this.
But it is much easier to use a monitor point and generate the data as the simulation runs. For your next simulation I recommend you do this. |
