February 8, 2013, 15:08 |
CFX highly skewness after remeshing
Mohamad Alagheband
Rep Power: 13 |
hello friends
I have problem for remeshing I have done edr tutorial in this forum but after remeshing an error occured new mesh was not fine and negative volume have been created in remeshin process. Does any anybody know about it? I've got same problem with finer mesh! |
February 11, 2013, 08:17 |
Rep Power: 15 |
which inflation algorithm did you use?
did you clear generated data before? |
February 11, 2013, 14:05 |
#3 | |
Mohamad Alagheband
Rep Power: 13 |
I'm sorry I don't know what you really mean. i am not so expert but i used unstructured mesh with octree type i ran script control befor defining global mesh setup(global mesh size) and seved that after computing mesh. i added curves ,points and surface to proper BC.(actually to a proper part) i start with surface meshing and then computing.Is this problem? Last edited by MUMMED; February 11, 2013 at 16:23. |
February 12, 2013, 09:58 |
Edmund Singer P.E.
Rep Power: 20 |
You are using ICEM?
Did you check the geom it built up from the old mesh to see if it it correct? Make sure lines and points are generated correctly and not just surfaces. You might need to script in a geom Build Topology after generating geom from old mesh to correct this. If geom is all ok then try decreasing the Edge Criterion for the Octree Volume mesher. |
February 12, 2013, 12:21 |
#5 | |
Mohamad Alagheband
Rep Power: 13 |
my first problem was that you mentioned i set ICEM CFD Scale factor but i don't know why the geometry scale is not aproppriate after remeshing? |
Remeshing in OpenFOAM | prasanth | OpenFOAM | 1 | October 7, 2017 17:41 |
Different flow pattern between OpenFOAM and CFX | AirS | OpenFOAM | 0 | January 12, 2010 07:08 |
CFX 12.0 remeshing error | songxguan | CFX | 1 | November 26, 2009 06:14 |
Severe nonorthogonality and severe skewness problem | qtian | OpenFOAM Running, Solving & CFD | 2 | January 22, 2008 18:47 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 05:59 |
