Home > Forums > CFX
Introducing normalized velocity
Old   February 11, 2013, 09:56
Default Introducing normalized velocity
Govindaraju
kmgraju is on a distinguished road
Dear friends
I would like to introduce normalized velocity profile as an input. The velocity changes with respect to time under different condition. So I did normalized the data (0 to 1).
Now the output data has no unit ( assume I am correct). How to introduce this normalized data to the input boundary condition in the velocity field?
Thank you for your kind attention
Regards
Govind
kmgraju is offline   Reply With Quote
Old   February 11, 2013, 18:15
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
Velocity boundaries need an input in units of length/time, so you just need to un-normalise it.
Alternately you can trick CFX into using non-dimensional inputs providing you work the unit change through all units in the simulation and end up with a consistent set of units (which are actually unitless ). Using this you can do non-dimensional simulations in CFX.
Old   February 11, 2013, 23:53
Govindaraju
Dear Mr. Glenn
That means I have to choose simply all the dimensionless number to velocity unit. Am I correct?
If this is the case, the maximum velocity becomes 1 m/s and minimum velocity becomes 0 m/s.
in my data at t=0, the normalized value is 0.7070 . this value corresponds to
0.2375 m/s ( un normalized value).
In a global initialization, what is the initial value at t= 0 s? . Is it 0.7070 or 0.2375?
( I put at t=0, velocity 0.7070 m/s).
If I use normalized value , one simulation is sufficient. Am I correct?
If I want to change the input parameter for the next result, what is the procedure?
( Note: If I use normalized method other set of readings also traces the same value )
Thank you
Regards
Govind
Old   February 12, 2013, 07:08
No matter what you do the unit system you use has to be consistent.
It can either be a non-dimensional scheme or a quasi-dimensional scheme (simply un-normalising your velocities). What is the best approach will depend on what information you know and what you are trying to achieve.
Old   February 12, 2013, 07:26
Govindaraju
Thank you Mr Glenn
I will try my best
Regards
Govind
Old   February 19, 2013, 00:18
Shashwat
shaswat is on a distinguished road
Dear friends
I have an CEL expression for velocity U(t)= U(max)[1+sin (4*pi*f*t- (pi/2))]
for my simulation I want to change U(max ) everytime.
If I convert into normalized, I got a same curve for all the U(max) values.
Now, is there any way to proceed with single simulation and get multiple results for different U(max) values?
Regards
Shashwat
shaswat is offline   Reply With Quote
Old   February 19, 2013, 04:58
Do you want to see the result for a series of U(max) values in a steady state simulation? The best way to do this is to either script up a series of steady state runs, possibly using other runs as intial conditions to speed sonvergence; OR use a multiple configuration def file to do multiple setups OR use workbench to do a parametric sweep.
There's three ways of doing it, you choose the one you like the best.
Old   February 19, 2013, 22:02
Shashwat
dear friend
No my simulations are transient simulation.
can you please explain bit.
I thought in the following way,please correct me if I am wrong.
the normalized velocity curve is simillar for the series of U(max).so find the normalized factor . DO one simulation un-normalized velocity as an input and find the result in cfx post.
If I want to do series of u (max) , can I simply multiply with normalized factor?.simillary ,can I multiply the normalized factor with result in cfx post?.
is the way correct ?
Thank you
Regards
Thread Tools
Trackbacks are On
Plotting Radial Velocity and Tangential Velocity in CFD Post ashtonJ CFX 5 July 13, 2015 02:49
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 05:35
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 07:10
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
