February 11, 2013, 08:56 |
Introducing normalized velocity
Govindaraju
Dear friends
I would like to introduce normalized velocity profile as an input. The velocity changes with respect to time under different condition. So I did normalized the data (0 to 1). Now the output data has no unit ( assume I am correct). How to introduce this normalized data to the input boundary condition in the velocity field? Thank you for your kind attention Regards Govind |
February 11, 2013, 17:15 |
Rep Power: 143 |
Velocity boundaries need an input in units of length/time, so you just need to un-normalise it.
Alternately you can trick CFX into using non-dimensional inputs providing you work the unit change through all units in the simulation and end up with a consistent set of units (which are actually unitless ). Using this you can do non-dimensional simulations in CFX. |
February 11, 2013, 22:53 |
#3 | |
Govindaraju
That means I have to choose simply all the dimensionless number to velocity unit. Am I correct? If this is the case, the maximum velocity becomes 1 m/s and minimum velocity becomes 0 m/s. in my data at t=0, the normalized value is 0.7070 . this value corresponds to 0.2375 m/s ( un normalized value). In a global initialization, what is the initial value at t= 0 s? . Is it 0.7070 or 0.2375? ( I put at t=0, velocity 0.7070 m/s). If I use normalized value , one simulation is sufficient. Am I correct? If I want to change the input parameter for the next result, what is the procedure? ( Note: If I use normalized method other set of readings also traces the same value ) Thank you Regards Govind |
February 12, 2013, 06:08 |
Rep Power: 143 |
No matter what you do the unit system you use has to be consistent.
It can either be a non-dimensional scheme or a quasi-dimensional scheme (simply un-normalising your velocities). What is the best approach will depend on what information you know and what you are trying to achieve. |
February 12, 2013, 06:26 |
#5 | |
Govindaraju
I will try my best Regards Govind |
February 18, 2013, 23:18 |
#6 | |
Shashwat
Dear friends I have an CEL expression for velocity U(t)= U(max)[1+sin (4*pi*f*t- (pi/2))] for my simulation I want to change U(max ) everytime. If I convert into normalized, I got a same curve for all the U(max) values. Now, is there any way to proceed with single simulation and get multiple results for different U(max) values? Regards Shashwat |
February 19, 2013, 03:58 |
Rep Power: 143 |
Do you want to see the result for a series of U(max) values in a steady state simulation? The best way to do this is to either script up a series of steady state runs, possibly using other runs as intial conditions to speed sonvergence; OR use a multiple configuration def file to do multiple setups OR use workbench to do a parametric sweep.
There's three ways of doing it, you choose the one you like the best. |
February 19, 2013, 21:02 |
#8 | |
Shashwat
No my simulations are transient simulation. can you please explain bit. I thought in the following way,please correct me if I am wrong. the normalized velocity curve is simillar for the series of U(max).so find the normalized factor . DO one simulation un-normalized velocity as an input and find the result in cfx post. If I want to do series of u (max) , can I simply multiply with normalized factor?.simillary ,can I multiply the normalized factor with result in cfx post?. is the way correct ? Thank you Regards |
April 10, 2024, 03:51 |
normalized velocity
prashant godse
Rep Power: 2 |
how to calculate normalized velocity and normalized helicity in cfx if any cel expression or somthing that would of great help. i am trying to visualized secondary flow in rotor 67
April 10, 2024, 04:30 |
Rep Power: 143 |
Define a new variable in CFD-Post with the normalisation function you want to use. So do this in the post-processor, not the solver, if at all possible.
April 10, 2024, 04:36 |
#11 |
prashant godse
Rep Power: 2 |
ok got it, i have another question like for normalised velocity i need to find averaged streamline velocity at 99% span. i have created a turbosurface with 99% span how can i calculate averaged velocity
April 10, 2024, 04:45 |
#12 |
Rep Power: 143 |
Have you done the CFD-Post tutorials? That is the best way to learn the capabilities of the software and how to do it.
April 10, 2024, 04:47 |
#13 |
prashant godse
Rep Power: 2 |
ok will check for it. thanks
Plotting Radial Velocity and Tangential Velocity in CFD Post | ashtonJ | CFX | 5 | July 13, 2015 02:49 |
Steady pipe flow mean velocity higher than inlet velocity | anita | OpenFOAM Running, Solving & CFD | 7 | September 25, 2012 05:35 |
Velocity in Porous medium : HELP! HELP! HELP! | Kali Sanjay | Phoenics | 0 | November 6, 2006 06:10 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
