-   -   ask for help :about cfx turbogrid (http://www.cfd-online.com/Forums/cfx/114084-ask-help-about-cfx-turbogrid.html)
captain March 5, 2013 02:34
i want to form a stator .but when i put in the profile ,it gives a warn:
"WARNING
First blade profile is not defined as a hub tip and is too far (0.0945101 of span) from the
hub for reliable surface intersection.Surface extension factor will be adjusted accordingly, however application may become unreliable.
ERROR
Last blade profile is not defined as a shroud tip and is too far (0.858225 of span) from the
shroud for reliable intersection. Must be at least 0.858235 of span. "
i tried some ways ,but can't solve it .Can anybody help me about this question ?thank you!
Veronique Pe June 13, 2014 08:14
redefine hub coordinates with blade profile at 0% of span coordinates
I think your blade profile at 0% of span is not corresponding to yourhub profile.
Do you try to redefine the hub profile in using the blade profile at 0% of span coordinates? and use 100% of span blade profile coordinates to redefine the shroud coordinates? (plus coordinates to define inlet and outlet domains)
I think my problem is similar:
Surfaces Blade_1_tr_low and Blade_1_sh_tip_rot do not intersect.
Keep me in the loop
Ahmed Saeed Mansour August 13, 2016 18:56
How can I do this or have you solved it?
