[Sponsors] | |||||
Martin
Rep Power: 4 ![]() |
Hello everybody.
I am currently simulating natural convection of a multicomponent mixture (helium, air and water vapor) induced by heat sources inside a pressurized conatainment. So far my results are quite unrealistic since it is evident that the fluids inside are mixing at a high rate due to gravitational/bouyancy effects. The natural convection that should occur due to mixture heating is miniscule so far. I am using the k-epsilon model for turbulence modeling. I have also compared cases with different dissipation coefficients and different Schmidt numbers (1 and 100) but the results are still the same - rapid mixing and degradation of a helium cloud (positioned at the top of the vessel) due to fluid flow which is moving downward to fast. I would like to know if anyone knows how can I manage the process of such rapid mixing? Thank you all in advance. |
Rep Power: 59 ![]() ![]() ![]() |
General points are covered in the FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Something is causing an unrealistically high fluid motion from your description. You have to look into the details of your setup to find it. |
Martin
The mesh metrics are good. I have tried different settings in the buoyancy turbulence tab (production, production and dissipatin, changing values of Sc number and dissipation coefficient), advection and turbulence schemes. My timestep value varies from 0.05 to 0.04 s, which is sufficiently small since the fluid velocities are relatively small.
I have also made a similar mesh (extruded model whereas the main simulation is based on a cillindrical/revolved model). The mesh metrics are excellent. I have enabled buoyancy,changed intial conditions from standard room temperature and pressure to the same conditions that are given from the experiment. The results are similar then before. The helium cloud at the top of the room degrades and moves towards the floor within 10 seconds. From this facts follows that the mesh is not the problem. The initial conditions that I have used are the same as those that were used in a different simulation but still calculating the same physical phenomenon. |
#4 | ||
Can you post an image of what you are modeling? |
Martin
Thank you for your help so far but all the statements above are made based on the articles I have studied to make such a simulation. I am well aware that the end result of a simulation depends on multiple factors, settings, initial conditions etc.
But the main topic of the thread remains the same. What else could I change to make my simulation a bit more realistic? |
So far you have only provided general details about your simulation, so all I can do is give general suggestions. If you want more specific comments you will have to describe what you are modelling in more detail. Post an image and attach the CCL.
Martin
I am modeling natural convection (caused by a heat source) in a pressurized containment. To be more specific, I am researching the degradation of a helium cloud which is situated at the top of the containment volume.
Because I had difficulties with the original case I created a simple case of a room which has a wall surrounding it to see which settings in CFX-Pre are causing unrealistic results for my type of simulation. This case actually serves me as a sensitivity analysis to find out why the helium cloud degrades too fast (which is occurring in when using both grids). Within approx. 10 seconds the helium cloud deforms and falls to the bottom of the room/vessel. Experimental data (taken inside the vessel) shows that the helium cloud does not dissolve for about 100 seconds. Grid: http://postimage.org/image/gy0fvmb6l/ CCL: &replace FLOW: Flow Analysis 1 ANALYSIS TYPE: Option = Transient EXTERNAL SOLVER COUPLING: Option = None END INITIAL TIME: Option = Automatic with Value Time = 0 [s] END TIME DURATION: Option = Total Time Total Time = 10 [s] END TIME STEPS: Option = Timesteps Timesteps = 0.05 [s] END END DOMAIN INTERFACE: Default Fluid Fluid Interface Boundary List1 = Default Fluid Fluid Interface Side 1 1 Boundary List2 = Default Fluid Fluid Interface in He atm Side 1 Filter Domain List1 = AirSteam atm Filter Domain List2 = He atm Interface Region List1 = F100.106 Interface Region List2 = F100.105 Interface Type = Fluid Fluid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END MASS AND MOMENTUM: Option = Conservative Interface Flux MOMENTUM INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = GGI END END DOMAIN INTERFACE: Default Fluid Solid Interface Boundary List1 = Default Fluid Solid Interface in He atm Side 1,Default Fluid Solid Interface in VPZr Side 1 Boundary List2 = Default Fluid Solid Interface in zunanja stena Side 2 Filter Domain List1 = AirSteam atm,He atm Filter Domain List2 = wall Interface Region List1 = F101.105,F102.105,F98.106,F99.106 Interface Region List2 = F101.104,F102.104,F98.104,F99.104 Interface Type = Fluid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = GGI END END DOMAIN: AirSteam atm Coord Frame = Coord 0 Domain Type = Fluid Location = B106 BOUNDARY: Default Fluid Fluid Interface Side 1 1 Boundary Type = INTERFACE Interface Boundary = On Location = F100.106 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: Default Fluid Solid Interface in VPZr Side 1 Boundary Type = INTERFACE Interface Boundary = On Location = F98.106,F99.106 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = No Slip Wall END WALL CONTACT MODEL: Option = Use Volume Fraction END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: gsk2zg Boundary Type = WALL Create Other Side = Off Interface Boundary = Off Location = F97.106 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END MASS AND MOMENTUM: Option = No Slip Wall END WALL CONTACT MODEL: Option = Use Volume Fraction END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: sim21 Boundary Type = SYMMETRY Interface Boundary = Off Location = sim21 END BOUNDARY: sim22 Boundary Type = SYMMETRY Interface Boundary = Off Location = sim22 END DOMAIN MODELS: BUOYANCY MODEL: Buoyancy Reference Density = 0.2 [kg m^-3] Gravity X Component = 0 [m s^-2] Gravity Y Component = 9.81 [m s^-2] Gravity Z Component = 0 [m s^-2] Option = Buoyant BUOYANCY REFERENCE LOCATION: Cartesian Coordinates = 0.0[m],0.0[m],0.0[m] Option = Cartesian Coordinates END END DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END REFERENCE PRESSURE: Reference Pressure = 1.013 [bar] END END FLUID DEFINITION: air Material = Air at STP Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID DEFINITION: helij Material = He at STP Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID DEFINITION: steam Material = Water Vapour at 100 C Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID MODELS: COMBUSTION MODEL: Option = None END FLUID: air FLUID BUOYANCY MODEL: Option = Density Difference END END FLUID: helij FLUID BUOYANCY MODEL: Option = Density Difference END END FLUID: steam FLUID BUOYANCY MODEL: Option = Density Difference END END HEAT TRANSFER MODEL: Homogeneous Model = On Option = Total Energy END THERMAL RADIATION MODEL: Option = None END TURBULENCE MODEL: Homogeneous Model = On Option = k epsilon BUOYANCY TURBULENCE: Option = Production END END TURBULENT WALL FUNCTIONS: High Speed Model = Off Option = Scalable END END FLUID PAIR: air | helij INTERPHASE TRANSFER MODEL: Interface Length Scale = 1. [mm] Option = Mixture Model END MASS TRANSFER: Option = None END MOMENTUM TRANSFER: DRAG FORCE: Drag Coefficient = 0.44 Option = Drag Coefficient END END END FLUID PAIR: air | steam INTERPHASE TRANSFER MODEL: Interface Length Scale = 1. [mm] Option = Mixture Model END MASS TRANSFER: Option = None END MOMENTUM TRANSFER: DRAG FORCE: Drag Coefficient = 0.44 Option = Drag Coefficient END END END FLUID PAIR: helij | steam INTERPHASE TRANSFER MODEL: Interface Length Scale = 1. [mm] Option = Mixture Model END MASS TRANSFER: Option = None END MOMENTUM TRANSFER: DRAG FORCE: Drag Coefficient = 0.44 Option = Drag Coefficient END END END INITIALISATION: Coord Frame = Coord 0 Option = Automatic FLUID: air INITIAL CONDITIONS: Velocity Type = Cartesian CARTESIAN VELOCITY COMPONENTS: Option = Automatic with Value U = 0 [m s^-1] V = 0 [m s^-1] W = 0 [m s^-1] END VOLUME FRACTION: Option = Automatic with Value Volume Fraction = 1 END END END FLUID: helij INITIAL CONDITIONS: Velocity Type = Cartesian CARTESIAN VELOCITY COMPONENTS: Option = Automatic with Value U = 0 [m s^-1] V = 0 [m s^-1] W = 0 [m s^-1] END VOLUME FRACTION: Option = Automatic with Value Volume Fraction = 0 END END END FLUID: steam INITIAL CONDITIONS: Velocity Type = Cartesian CARTESIAN VELOCITY COMPONENTS: Option = Automatic with Value U = 0 [m s^-1] V = 0 [m s^-1] W = 0 [m s^-1] END VOLUME FRACTION: Option = Automatic with Value Volume Fraction = 0 END END END INITIAL CONDITIONS: STATIC PRESSURE: Option = Automatic with Value Relative Pressure = 0.187 [bar] END TEMPERATURE: Option = Automatic with Value Temperature = Tzac END TURBULENCE INITIAL CONDITIONS: Option = k and Epsilon EPSILON: Epsilon = 1e-06 [m^2 s^-3] Option = Automatic with Value END K: Option = Automatic with Value k = 1e-06 [m^2 s^-2] END END END END MULTIPHASE MODELS: Homogeneous Model = False FREE SURFACE MODEL: Option = None END END END DOMAIN: He atm Coord Frame = Coord 0 Domain Type = Fluid Location = B105 BOUNDARY: Default Fluid Fluid Interface in He atm Side 1 Boundary Type = INTERFACE Interface Boundary = On Location = F100.105 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: Default Fluid Solid Interface in He atm Side 1 Boundary Type = INTERFACE Interface Boundary = On Location = F101.105,F102.105 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = No Slip Wall END WALL CONTACT MODEL: Option = Use Volume Fraction END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: gsk1zg Boundary Type = WALL Create Other Side = Off Interface Boundary = Off Location = F103.105 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END MASS AND MOMENTUM: Option = No Slip Wall END WALL CONTACT MODEL: Option = Use Volume Fraction END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: sim11 Boundary Type = SYMMETRY Interface Boundary = Off Location = sim11 END BOUNDARY: sim12 Boundary Type = SYMMETRY Interface Boundary = Off Location = sim12 END DOMAIN MODELS: BUOYANCY MODEL: Buoyancy Reference Density = 0.2 [kg m^-3] Gravity X Component = 0 [m s^-2] Gravity Y Component = 9.81 [m s^-2] Gravity Z Component = 0 [m s^-2] Option = Buoyant BUOYANCY REFERENCE LOCATION: Cartesian Coordinates = 0.0[m],0.0[m],0.0[m] Option = Cartesian Coordinates END END DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END REFERENCE PRESSURE: Reference Pressure = 1.013 [bar] END END FLUID DEFINITION: air Material = Air at STP Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID DEFINITION: helij Material = He at STP Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID DEFINITION: steam Material = Water Vapour at 100 C Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID MODELS: COMBUSTION MODEL: Option = None END FLUID: air FLUID BUOYANCY MODEL: Option = Density Difference END END FLUID: helij FLUID BUOYANCY MODEL: Option = Density Difference END END FLUID: steam FLUID BUOYANCY MODEL: Option = Density Difference END END HEAT TRANSFER MODEL: Homogeneous Model = On Option = Total Energy END THERMAL RADIATION MODEL: Option = None END TURBULENCE MODEL: Homogeneous Model = On Option = k epsilon BUOYANCY TURBULENCE: Option = Production END END TURBULENT WALL FUNCTIONS: High Speed Model = Off Option = Scalable END END FLUID PAIR: air | helij INTERPHASE TRANSFER MODEL: Interface Length Scale = 1. [mm] Option = Mixture Model END MASS TRANSFER: Option = None END MOMENTUM TRANSFER: DRAG FORCE: Drag Coefficient = 0.44 Option = Drag Coefficient END END END FLUID PAIR: air | steam INTERPHASE TRANSFER MODEL: Interface Length Scale = 1. [mm] Option = Mixture Model END MASS TRANSFER: Option = None END MOMENTUM TRANSFER: DRAG FORCE: Drag Coefficient = 0.44 Option = Drag Coefficient END END END FLUID PAIR: helij | steam INTERPHASE TRANSFER MODEL: Interface Length Scale = 1. [mm] Option = Mixture Model END MASS TRANSFER: Option = None END MOMENTUM TRANSFER: DRAG FORCE: Drag Coefficient = 0.44 Option = Drag Coefficient END END END INITIALISATION: Coord Frame = Coord 0 Option = Automatic FLUID: air INITIAL CONDITIONS: Velocity Type = Cartesian CARTESIAN VELOCITY COMPONENTS: Option = Automatic with Value U = 0 [m s^-1] V = 0 [m s^-1] W = 0 [m s^-1] END VOLUME FRACTION: Option = Automatic with Value Volume Fraction = 0 END END END FLUID: helij INITIAL CONDITIONS: Velocity Type = Cartesian CARTESIAN VELOCITY COMPONENTS: Option = Automatic with Value U = 0 [m s^-1] V = 0 [m s^-1] W = 0 [m s^-1] END VOLUME FRACTION: Option = Automatic with Value Volume Fraction = 1 END END END FLUID: steam INITIAL CONDITIONS: Velocity Type = Cartesian CARTESIAN VELOCITY COMPONENTS: Option = Automatic with Value U = 0 [m s^-1] V = 0 [m s^-1] W = 0 [m s^-1] END VOLUME FRACTION: Option = Automatic with Value Volume Fraction = 0 END END END INITIAL CONDITIONS: STATIC PRESSURE: Option = Automatic with Value Relative Pressure = 0.187 [bar] END TEMPERATURE: Option = Automatic with Value Temperature = Tzac END TURBULENCE INITIAL CONDITIONS: Option = k and Epsilon EPSILON: Epsilon = 1e-06 [m^2 s^-3] Option = Automatic with Value END K: Option = Automatic with Value k = 1e-06 [m^2 s^-2] END END END END MULTIPHASE MODELS: Homogeneous Model = False FREE SURFACE MODEL: Option = None END END END DOMAIN: wall Coord Frame = Coord 0 Domain Type = Solid Location = B104 BOUNDARY: Default Fluid Solid Interface in zunanja stena Side 2 Boundary Type = INTERFACE Interface Boundary = On Location = F101.104,F102.104,F98.104,F99.104 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END END END BOUNDARY: sim31 Boundary Type = SYMMETRY Interface Boundary = Off Location = sim31 END BOUNDARY: sim32 Boundary Type = SYMMETRY Interface Boundary = Off Location = sim32 END BOUNDARY: wall Default Boundary Type = WALL Create Other Side = Off Interface Boundary = Off Location = F103.104,F97.104 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END END END BOUNDARY: zunanje stene Boundary Type = WALL Create Other Side = Off Interface Boundary = Off Location = zunanje stene BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END END END DOMAIN MODELS: DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END END INITIALISATION: Option = Automatic INITIAL CONDITIONS: TEMPERATURE: Option = Automatic with Value Temperature = Tzac END END END SOLID DEFINITION: Solid 1 Material = Steel Option = Material Library MORPHOLOGY: Option = Continuous Solid END END SOLID MODELS: HEAT TRANSFER MODEL: Option = Thermal Energy END THERMAL RADIATION MODEL: Option = None END END END OUTPUT CONTROL: RESULTS: File Compression Level = Default Option = Standard END TRANSIENT RESULTS: Transient Results 1 File Compression Level = Default Include Mesh = No Option = Selected Variables Output Variables List = Absolute Pressure,helij.Total Density,helij.Total Temperature,helij.Velocity,helij.Velocity u,helij.Velocity v,helij.Velocity w,helij.Volume Fraction,helij.Vorticity OUTPUT FREQUENCY: Option = Timestep Interval Timestep Interval = 5 END END END SOLUTION UNITS: Angle Units = [rad] Length Units = [m] Mass Units = [kg] Solid Angle Units = [sr] Temperature Units = [K] Time Units = [s] END SOLVER CONTROL: Turbulence Numerics = High Resolution ADVECTION SCHEME: Option = High Resolution END CONVERGENCE CONTROL: Maximum Number of Coefficient Loops = 5 Minimum Number of Coefficient Loops = 3 Timescale Control = Coefficient Loops END CONVERGENCE CRITERIA: Residual Target = 1.E-4 Residual Type = RMS END TRANSIENT SCHEME: Option = Second Order Backward Euler TIMESTEP INITIALISATION: Option = Automatic END END END END |
Some comments:
* Why is there a fluid fluid interface? This looks like it can be done as a single domain. * Is this a CHT simulation as well? If you are looking at the mixing of the He cloud why does CHT matter? * Shouldn't your gravity vector be y=-9.81 [m/s]? You seem to have gravity in the wrong direction. * Are you sure this simulation is turbulent? Have you checked the relevant non-dimensional numbers? * (This is a big mistake) You are modelling this as a multiphase model. But there is only a single phase, being gas. You should be modelling this as a multi-component mixture. Read the documentation on the definition of multiphase and multicomponent mixtures as the difference is critical - as you will find out when you try it. * Why are you restricting it to 3-5 coeff loops per time step? Let it use a good number for a maximum and don't bother with a minimum. |
#9 |
Martin
1) Is there any other way to model the helium cloud?
(I was thinking about writing a CEL expression of the helium mass concentration/fraction distribution but so far my knowledge about CFX is poor.) 2) The main simulation involves a steel compartment (cylinder) inside the vessel. Also the outer walls of the containment are made of steel so I have to assume that a part of the heat energy gets stored in the walls and the cylinder. That is why I have to consider the calorific effects of the inner and outer structure. 3) Fixed the gravity 4) Over time natural convection is is expected to occur due to heating of the surfaces inside the vessel. Based on previous simulations made and research done on similar cases the flow that occurs is considered turbulent. 5) Looked at the tutorials (properly this time) and changed the settings. 6) I have chosen this setting based on the modeling guide in ANSYS help: "A value of 3 iterations per timestep should be sufficient for most single phase simulations, and values higher than 5 are unlikely to improve accuracy. In multiphase cases, the default value of 10 iterations per timestep may be more appropriate." Here is the link for the actual mesh that I will be using: http://postimage.org/image/q2gjrz0l5/ Thank you very much for your help. I appreciate it. |
#10 |
1) Yes. Model the entire fluid domain as a single domain. Then use a CEL expression to set the initial condition, using a function of space. For instance Helium.mass fraction=if(z>10[m],1.0,0.0) sets the mass fraction of He to 1.0 above z=10m.
2) If you are interested in heat effects then fair enough, model the casing. 3) ![]() 4) OK, if you know the flow is turbulent then model it as turbulent. But I would still work out the relevant non-dimensional numbers to determine if you are just turbulent or strongly turbulent. If you are just turbulent I would probably not use a turbulence model and use a laminar model. But if strongly turbulent I would use a turbulence model. 5) This will dramatically change the results. You are now saying molecular diffusion is the mixing process, rather than "particles" of one gas inside the other. Obviously this particle assumption is rubbish, and hence your initial results are totally wrong. 6) No, you have taken the doco comments the wrong way. You should use a min of 3 and a max of 5 as targets for adaptive time stepping, with limit values (which is what you set) of around 10 max and no minimum. Then the simulation will automatically find its time step size in the ideal range. 7) With regards your mesh: This looks like a 2D axisymmetric model, so try to generate the mesh to be a single element thick. It can be diffiicult to convince Workbench to do this sometimes (it does have a mind of its own for these things....), but it will significantly speed you simulation up if you do. |
#11 |
Martin
Mr. Horrocks,
thank you for the advice and especially you time for helping me out. I have implemented (almost) all of the above settings in my simulation. I have another question regarding the initial conditions and CEL expressions. I have experimental values for the initial conditions for He mass fraction which vary with height. For example: from 5 to 6 meters the mass fraction goes from 0 to 0.005 and from 6 to 7 meters it goes from 0.005 to 0.095. What I would like to do is to implement this data or write a CEL expression that would describe the He mass fraction gradient as it is shown on the diagram in the picture: http://postimg.org/image/y5ry85pfn/ Can I use a for loop in the CEL expression? I was going through the CEL manual but couldn't find any explanation or examples for such a case. |
#12 |
CEL does not have for loops. Your function is easy to implement as a 1D interpolation function with height (y) as the input variable.
#13 |
OJ
Rep Power: 7 ![]() |
If you are are having problems of quality of mesh at the axis, you can chop off the edge at the axis. Often there are spurious results at the axis due to this bad quality zone. After chopping off the edge, there won't be a sharp corner and specify the resultant small wall as symmetry or free slip wall.
OJ |
#14 |
Martin
OJ I already did that at the beginning (which I forgot to mention)
![]() Thanks for the heads up anyway. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| natural convection problem with radiation | jorien | CFX | 0 | October 14, 2011 09:26 |
| Approximate Mixing due to Natural Convection | Greg Perkins | Main CFD Forum | 0 | February 12, 2003 18:43 |
| Mixing By Natural Convection Processes | Greg Perkins | FLUENT | 0 | February 12, 2003 18:40 |
| Heat of mixing - natural convection | Andre | Main CFD Forum | 0 | May 10, 2000 05:42 |
| Heat of mixing - natural convection | Andre | FLUENT | 0 | May 10, 2000 05:40 |
