How to measure incidence angle
Old   March 12, 2013, 07:06
Default How to measure incidence angle
Prashant Kumar Singh
pks126 is on a distinguished road
Dear All,
I have a result file in cfx & i have to calculate incidence angle at Tip LE of a compressor blade.How to calculate it in cfx-post?
Thanks,
pks126 is offline   Reply With Quote
Old   March 13, 2013, 09:07
OJ
oj.bulmer will become famous soon enough
Can you post an image to make your question clear?
OJ
oj.bulmer is offline   Reply With Quote
Old   March 13, 2013, 11:18
thanks bulmer
can you tell me how to calculate incidence angle for airfoil or compressor blade numerically then i can try this in cfx.
regards,
Old   March 13, 2013, 11:28
OJ
This is what comes to mind. How about measuring actual values of u, v, w at the tip of the blade etc? You can then get a vector in 3D space. From the trigonometry and orientation of your blade coordinate system with this vector, you can calculate the angle. If you are trying to find on the angle of incidence on the edge, you may want to take average values of u,v, w at that and then figure out the vector.
Not an elegant way but should give you an idea.
OJ
Old   March 13, 2013, 11:37
i have values of u v w @ LE point ....but this is little difficult process ....
thanks
Particle Incidence Angle vs erosion ratio XY plot alan81 STAR-CCM+ 3 May 6, 2015 10:32
Flow at an angle of incidence saisanthoshm88 CFX 1 July 14, 2012 05:19
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
How to measure angle of flow rk2011 Main CFD Forum 2 February 10, 2011 14:05
Incidence and deviation angle for axial turbomachines csmistry CFX 4 October 25, 2010 07:11
