Home > Forums > CFX
Cfx-Pre subdomain
Old   March 14, 2013, 03:38
Default Cfx-Pre subdomain
izzy is on a distinguished road
I have a question about the function subdomain in cfx-pre. The general Momentum Source should be realised as a function on the float, but i just can realise a value or expression on this area.. Is it possible to realise the momentum source as a function? and do somebody know how?
Hope its very well described.
Thanks!
izzy is offline   Reply With Quote
Old   March 14, 2013, 06:30
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
Yes, sources can be functions. This is well described in the documentation.
Old   March 15, 2013, 04:01
Lance
Lance is on a distinguished road
A related question: is there a way to create a general momentum source on a point instead of a subdomain?
Lance is offline   Reply With Quote
Old   March 16, 2013, 06:09
The documentation states momentum sources are not available on points. I am not sure why, but I suspect it becomes a convergence problem. So the simple work-around is to use a little volume and mesh it with a single element (which is what point source act on anyway, this is not a simplification) so you can use a normal volume source.
Old   March 18, 2013, 02:55
Lance
Originally Posted by ghorrocks View Post
[...] simple work-around is to use a little volume and mesh it with a single element (which is what point source act on anyway, this is not a simplification) so you can use a normal volume source.
Yes, that's what Im doing at the moment. However, hexa meshing in icem becomes a real pain, and that's why I asked if someone knew a smart way around it.
Thread Tools
Trackbacks are On
CFX Pre Domains for centrifugal pump MechKim CFX 1 September 24, 2012 08:06
Error while opening cfx file in cfx pre pks126 CFX 5 September 7, 2012 13:19
Heat transfer settings in ANSYS CFX Pre. saisanthoshm88 CFX 1 November 6, 2010 07:14
CFX Pre Hide symmetry symbols alvid CFX 2 August 15, 2007 11:34
CFX 10 -pre and -post problams on Linux Henry Liu CFX 3 June 22, 2006 06:57
