A question about HP MPI Local Parallel
Old   March 14, 2013, 22:15
Default A question about HP MPI Local Parallel
Diego
nucfusion is on a distinguished road
Hello ,everyone:
when I using CFX to do parallel calculation ,some errors happend.The details are list below.In CFX-Solve Manager,I set run mode as HP MPI Local Parrallel .I don't know why this happend.Can you give me some suggestions?
| Job Information |
Run mode: parallel run (MPI)
Host computer: DEEPINXP
Par. Process: Master running on mesh partition: 1
Solver Build: Tue Apr 14 23:55:42 GMTDT 2009
Attributes: single-int32-32bit-novc8-noifort-novc6-optimised-su...
Job started: Tue Dec 15 22:44:09 2009
Par. Process: Slave running on mesh partition: 2
Unable to check out 2 licenses: No license for ANSYS CFX Solver Parallel could
be found.
| ERROR #001100247 has occurred in subroutine . |
| Message: |
| The solver is unable to continue because of licensing problems. |
| A license for the following capability level could not be checked |
| out: |
| PARALLEL PROCESSING |
| Please carefully examine the error message output above and check |
| that: |
| 1) The license server is specified correctly and is running. |
| 2) An appropriate license is available for checking out. |
| These problems can be checked using the ANSYS Client ANSLIC_ADMIN |
| utility. For further troubleshooting information please consult |
| ANSYS, Inc. Licensing Guide. |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
This run of the ANSYS CFX Solver has finished.
nucfusion is offline   Reply With Quote
Old   March 15, 2013, 02:04
Lance
Lance is on a distinguished road
Originally Posted by nucfusion View Post
[...] some errors happend.The details are list below.In CFX-Solve Manager,I set run mode as HP MPI Local Parrallel .I don't know why this happend.Can you give me some suggestions?
be found.
| Message:
| out:
| PARALLEL PROCESSING
| that:
The error message is quite clear, isnt it? Either the license server is unavailable, or you dont have the appropriate parallel license.
Lance is offline   Reply With Quote
Old   March 15, 2013, 02:07
Default Thanks
Diego
Thank you!
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
error while running in parallel using openmpi on local mc 6 processors suryawanshi_nitin OpenFOAM 10 February 22, 2017 21:33
InterFoam negative alpha karasa03 OpenFOAM 7 December 12, 2013 03:41
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 22:40
Ansys 14 Solver Manager only MPI Local Paralell. No Hp Mpi Cola1988 ANSYS 0 January 27, 2012 16:58
