Error finding variable "THERMX"
Hello Sir,
In my Transient Simulation of conjugate heat transfer problem i want to subtract heat transfer by convection (Q convection) from total radiation(Q) The equation is Q on wall = alpa*Q incident-Q convection-Q night sky The CEL Expression which i used is LIBRARY: CEL: &replace EXPRESSIONS: Dry Bulb = DRY BULB TEMP(t) Tlower = areaAve(T)@WALL_SIDE1 Tupper = areaAve(T)@WALL_SIDE2 K = 0.0261 [W m^-1 K^-1] alpa = 0.2 Kinematic Vis = 0.000016036 [m^2 s^-1] L = 1.075 [m] Pr = 0.707 q incident = GLOBAL RADIATION(t) q night sky = night sky radiation(t) Grashof = (g*beta*(Tupper-Dry Bulb)*L^3)/(Kinematic Vis^2) Ray = Grashof*Pr Nu L L = 0.27*(Ray^0.25) Nu L U = 0.54*(Ray^0.25) Nusselt = if(TSIDE1 > TSIDE2,Nu L L,Nu L U) h bar = (Nusselt*K)/(L) q con = h bar*(Tupper-Dry Bulb) q Net = (alpa*q incident Cealing)-q con Cealing-q night sky END END END but before starting run it is giving me error ERROR | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | NAME_MOD: Error finding variable "THERMX" how to fix this problem sir Thank you sir |
CFX error messages can be cryptic sometimes. Have you specified a variabel called THERMX? You will have to post your whole CCL for us to help I suspect. Also a diagram of what you are modelling would help.
Hello sir,
Thank you for your Reply,i have not used variable called THERMX in CFX pre variable in Present case i am just applying heat flux to top ceiling just to check weather the expression is working fine or not( my main aim is to subtract convection losses from global radiation with the help of expression. i have experimental values of global radiation) CCL &replace FLOW: Flow Analysis 1 ANALYSIS TYPE: Option = Transient EXTERNAL SOLVER COUPLING: Option = None END INITIAL TIME: Option = Automatic with Value Time = 0 [s] END TIME DURATION: Option = Total Time Total Time = 86400 [s] END TIME STEPS: Option = Timesteps Timesteps = 120 [s] END END DOMAIN INTERFACE: CEALING_ROOM Boundary List1 = CEALING_ROOM Side 1 Boundary List2 = CEALING_ROOM Side 2 Filter Domain List1 = ROOM Filter Domain List2 = CEALING Interface Region List1 = ROOM_CEILING Interface Region List2 = CEILING_ROOM Interface Type = Fluid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END HEAT TRANSFER: Option = Conservative Interface Flux HEAT TRANSFER INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = Automatic END END DOMAIN INTERFACE: CEALING_WALL Boundary List1 = CEALING_WALL Side 1 Boundary List2 = CEALING_WALL Side 2 Filter Domain List1 = CEALING Filter Domain List2 = WALL Interface Region List1 = CEILING_WALL Interface Region List2 = WALL_CEILING Interface Type = Solid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END HEAT TRANSFER: Option = Conservative Interface Flux HEAT TRANSFER INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = Automatic END END DOMAIN INTERFACE: SLABE_ROOM Boundary List1 = SLABE_ROOM Side 1 Boundary List2 = SLABE_ROOM Side 2 Filter Domain List1 = ROOM Filter Domain List2 = SLABE Interface Region List1 = ROOM_BASE Interface Region List2 = SLABE_ROOM Interface Type = Fluid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END HEAT TRANSFER: Option = Conservative Interface Flux HEAT TRANSFER INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = Automatic END END DOMAIN INTERFACE: SLABE_WALL Boundary List1 = SLABE_WALL Side 1 Boundary List2 = SLABE_WALL Side 2 Filter Domain List1 = SLABE Filter Domain List2 = WALL Interface Region List1 = SLABE_WALL Interface Region List2 = WALL_SLABE Interface Type = Solid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END HEAT TRANSFER: Option = Conservative Interface Flux HEAT TRANSFER INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = Automatic END END DOMAIN INTERFACE: WALL_ROOM_1 Boundary List1 = WALL_ROOM_1 Side 1 Boundary List2 = WALL_ROOM_1 Side 2 Filter Domain List1 = ROOM Filter Domain List2 = WALL Interface Region List1 = ROOM_WALL_1,ROOM_WALL_2,ROOM_WALL_3,ROOM_WALL_4 Interface Region List2 = WALL_ROOM_1,WALL_ROOM_2,WALL_ROOM_3,WALL_ROOM_4 Interface Type = Fluid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END HEAT TRANSFER: Option = Conservative Interface Flux HEAT TRANSFER INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = Automatic END END DOMAIN: CEALING Coord Frame = Coord 0 Domain Type = Solid Location = CEILING BOUNDARY: Adiabatic Boundary Type = WALL Create Other Side = Off Interface Boundary = Off Location = CEILING_CAVITY BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 0.8 Option = Opaque END END END BOUNDARY: CEALING_ROOM Side 2 Boundary Type = INTERFACE Interface Boundary = On Location = CEILING_ROOM BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 0.8 Option = Opaque END END END BOUNDARY: CEALING_WALL Side 1 Boundary Type = INTERFACE Interface Boundary = On Location = CEILING_WALL BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 1. Option = Opaque END END END BOUNDARY: TOP Boundary Type = WALL Create Other Side = Off Interface Boundary = Off Location = CEILING_ATM BOUNDARY CONDITIONS: HEAT TRANSFER: Heat Flux in = q con Option = Heat Flux END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 1 Option = Opaque END END END DOMAIN MODELS: DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END END SOLID DEFINITION: Solid 1 Material = CONCRETE Option = Material Library MORPHOLOGY: Option = Continuous Solid END END SOLID MODELS: HEAT TRANSFER MODEL: Option = Thermal Energy END THERMAL RADIATION MODEL: Number of Histories = 10000 Option = Monte Carlo Radiation Transfer Mode = Participating Media SCATTERING MODEL: Option = None END SPECTRAL MODEL: Option = Gray END END END END DOMAIN: ROOM Coord Frame = Coord 0 Domain Type = Fluid Location = ROOM BOUNDARY: CEALING_ROOM Side 1 Boundary Type = INTERFACE Interface Boundary = On Location = ROOM_CEILING BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = No Slip Wall END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 1. Option = Opaque END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: SLABE_ROOM Side 1 Boundary Type = INTERFACE Interface Boundary = On Location = ROOM_BASE BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = No Slip Wall END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 1. Option = Opaque END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: WALL_ROOM_1 Side 1 Boundary Type = INTERFACE Interface Boundary = On Location = ROOM_WALL_1,ROOM_WALL_2,ROOM_WALL_3,ROOM_WALL_4 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = No Slip Wall END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 1. Option = Opaque END WALL ROUGHNESS: Option = Smooth Wall END END END DOMAIN MODELS: BUOYANCY MODEL: Buoyancy Reference Temperature = 25 [C] Gravity X Component = 0 [m s^-2] Gravity Y Component = -9.81 [m s^-2] Gravity Z Component = 0 [m s^-2] Option = Buoyant BUOYANCY REFERENCE LOCATION: Option = Automatic END END DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END REFERENCE PRESSURE: Reference Pressure = 1 [atm] END END FLUID DEFINITION: Fluid 1 Material = Air at 25 C Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID MODELS: COMBUSTION MODEL: Option = None END HEAT TRANSFER MODEL: Option = Thermal Energy END THERMAL RADIATION MODEL: Option = Discrete Transfer Radiation Transfer Mode = Participating Media SCATTERING MODEL: Option = None END SPECTRAL MODEL: Option = Gray END END TURBULENCE MODEL: Option = k epsilon BUOYANCY TURBULENCE: Option = None END END TURBULENT WALL FUNCTIONS: Option = Scalable END END END DOMAIN: SLABE Coord Frame = Coord 0 Domain Type = Solid Location = SLABE BOUNDARY: ADIABATIC_WALL Boundary Type = WALL Create Other Side = Off Interface Boundary = Off Location = SLABE_SIDE_WALLS,SLABE_SOIL BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 0.8 Option = Opaque END END END BOUNDARY: SLABE_ROOM Side 2 Boundary Type = INTERFACE Interface Boundary = On Location = SLABE_ROOM BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 0.8 Option = Opaque END END END BOUNDARY: SLABE_WALL Side 1 Boundary Type = INTERFACE Interface Boundary = On Location = SLABE_WALL BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 1. Option = Opaque END END END DOMAIN MODELS: DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END END SOLID DEFINITION: Solid 1 Material = CONCRETE Option = Material Library MORPHOLOGY: Option = Continuous Solid END END SOLID MODELS: HEAT TRANSFER MODEL: Option = Thermal Energy END THERMAL RADIATION MODEL: Number of Histories = 10000 Option = Monte Carlo Radiation Transfer Mode = Participating Media SCATTERING MODEL: Option = None END SPECTRAL MODEL: Option = Gray END END END END DOMAIN: WALL Coord Frame = Coord 0 Domain Type = Solid Location = WALL BOUNDARY: CEALING_WALL Side 2 Boundary Type = INTERFACE Interface Boundary = On Location = WALL_CEILING BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END END END BOUNDARY: EAST_WALL Boundary Type = WALL Create Other Side = Off Interface Boundary = Off Location = WALL_CAVITY_1 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END END END BOUNDARY: North Wall Boundary Type = WALL Create Other Side = Off Interface Boundary = Off Location = WALL_CAVITY_2 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END END END BOUNDARY: SLABE_WALL Side 2 Boundary Type = INTERFACE Interface Boundary = On Location = WALL_SLABE BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END END END BOUNDARY: South Wall Boundary Type = WALL Create Other Side = Off Interface Boundary = Off Location = WALL_CAVITY_4 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END END END BOUNDARY: WALL_ROOM_1 Side 2 Boundary Type = INTERFACE Interface Boundary = On Location = WALL_ROOM_1,WALL_ROOM_2,WALL_ROOM_3,WALL_ROOM_4 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END END END BOUNDARY: West_Wall Boundary Type = WALL Create Other Side = Off Interface Boundary = Off Location = WALL_CAVITY_3 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END END END DOMAIN MODELS: DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END END INITIALISATION: Option = Automatic INITIAL CONDITIONS: TEMPERATURE: Option = Automatic with Value Temperature = 273 [K] END END END SOLID DEFINITION: Solid 1 Material = Brick Common Option = Material Library MORPHOLOGY: Option = Continuous Solid END END SOLID MODELS: HEAT TRANSFER MODEL: Option = Thermal Energy END THERMAL RADIATION MODEL: Option = None END END END INITIALISATION: Option = Automatic INITIAL CONDITIONS: Velocity Type = Cartesian CARTESIAN VELOCITY COMPONENTS: Option = Automatic with Value U = 0 [m s^-1] V = 0 [m s^-1] W = 0 [m s^-1] END RADIATION INTENSITY: Option = Automatic END STATIC PRESSURE: Option = Automatic with Value Relative Pressure = 0 [Pa] END TEMPERATURE: Option = Automatic with Value Temperature = 298 [K] END TURBULENCE INITIAL CONDITIONS: Option = Medium Intensity and Eddy Viscosity Ratio END END END OUTPUT CONTROL: MONITOR OBJECTS: MONITOR BALANCES: Option = Full END MONITOR FORCES: Option = Full END MONITOR PARTICLES: Option = Full END MONITOR RESIDUALS: Option = Full END MONITOR TOTALS: Option = Full END END RESULTS: File Compression Level = Default Option = Standard END TRANSIENT RESULTS: Transient Results 1 File Compression Level = Default Option = Standard OUTPUT FREQUENCY: Option = Time Interval Time Interval = 1000 [s] END END END SOLUTION UNITS: Angle Units = [rad] Length Units = [m] Mass Units = [kg] Solid Angle Units = [sr] Temperature Units = [K] Time Units = [s] END SOLVER CONTROL: Turbulence Numerics = High Resolution ADVECTION SCHEME: Option = High Resolution END CONVERGENCE CONTROL: Maximum Number of Coefficient Loops = 5 Minimum Number of Coefficient Loops = 1 Timescale Control = Coefficient Loops END CONVERGENCE CRITERIA: Residual Target = 0.00001 Residual Type = RMS END TRANSIENT SCHEME: Option = Second Order Backward Euler TIMESTEP INITIALISATION: Option = Automatic END END END END ################################################# but if we apply Ra = constant in expression it will run fine but that is not a actual case Thank you sir |
Hello sir,
Thank you for your Reply,i have not used variable called THERMX in CFX pre variable in Present case i am just applying heat flux to top ceiling just to check weather the expression is working fine or not( my main aim is to subtract convection losses from global radiation with the help of expression. i have experimental values of global radiation) Image http://postimg.org/image/wof4tkgoh/ CCL &replace FLOW: Flow Analysis 1 ANALYSIS TYPE: Option = Transient EXTERNAL SOLVER COUPLING: Option = None END INITIAL TIME: Option = Automatic with Value Time = 0 [s] END TIME DURATION: Option = Total Time Total Time = 86400 [s] END TIME STEPS: Option = Timesteps Timesteps = 120 [s] END END DOMAIN INTERFACE: CEALING_ROOM Boundary List1 = CEALING_ROOM Side 1 Boundary List2 = CEALING_ROOM Side 2 Filter Domain List1 = ROOM Filter Domain List2 = CEALING Interface Region List1 = ROOM_CEILING Interface Region List2 = CEILING_ROOM Interface Type = Fluid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END HEAT TRANSFER: Option = Conservative Interface Flux HEAT TRANSFER INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = Automatic END END DOMAIN INTERFACE: CEALING_WALL Boundary List1 = CEALING_WALL Side 1 Boundary List2 = CEALING_WALL Side 2 Filter Domain List1 = CEALING Filter Domain List2 = WALL Interface Region List1 = CEILING_WALL Interface Region List2 = WALL_CEILING Interface Type = Solid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END HEAT TRANSFER: Option = Conservative Interface Flux HEAT TRANSFER INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = Automatic END END DOMAIN INTERFACE: SLABE_ROOM Boundary List1 = SLABE_ROOM Side 1 Boundary List2 = SLABE_ROOM Side 2 Filter Domain List1 = ROOM Filter Domain List2 = SLABE Interface Region List1 = ROOM_BASE Interface Region List2 = SLABE_ROOM Interface Type = Fluid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END HEAT TRANSFER: Option = Conservative Interface Flux HEAT TRANSFER INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = Automatic END END DOMAIN INTERFACE: SLABE_WALL Boundary List1 = SLABE_WALL Side 1 Boundary List2 = SLABE_WALL Side 2 Filter Domain List1 = SLABE Filter Domain List2 = WALL Interface Region List1 = SLABE_WALL Interface Region List2 = WALL_SLABE Interface Type = Solid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END HEAT TRANSFER: Option = Conservative Interface Flux HEAT TRANSFER INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = Automatic END END DOMAIN INTERFACE: WALL_ROOM_1 Boundary List1 = WALL_ROOM_1 Side 1 Boundary List2 = WALL_ROOM_1 Side 2 Filter Domain List1 = ROOM Filter Domain List2 = WALL Interface Region List1 = ROOM_WALL_1,ROOM_WALL_2,ROOM_WALL_3,ROOM_WALL_4 Interface Region List2 = WALL_ROOM_1,WALL_ROOM_2,WALL_ROOM_3,WALL_ROOM_4 Interface Type = Fluid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END HEAT TRANSFER: Option = Conservative Interface Flux HEAT TRANSFER INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = Automatic END END DOMAIN: CEALING Coord Frame = Coord 0 Domain Type = Solid Location = CEILING BOUNDARY: Adiabatic Boundary Type = WALL Create Other Side = Off Interface Boundary = Off Location = CEILING_CAVITY BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 0.8 Option = Opaque END END END BOUNDARY: CEALING_ROOM Side 2 Boundary Type = INTERFACE Interface Boundary = On Location = CEILING_ROOM BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 0.8 Option = Opaque END END END BOUNDARY: CEALING_WALL Side 1 Boundary Type = INTERFACE Interface Boundary = On Location = CEILING_WALL BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 1. Option = Opaque END END END BOUNDARY: TOP Boundary Type = WALL Create Other Side = Off Interface Boundary = Off Location = CEILING_ATM BOUNDARY CONDITIONS: HEAT TRANSFER: Heat Flux in = q con Option = Heat Flux END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 1 Option = Opaque END END END DOMAIN MODELS: DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END END SOLID DEFINITION: Solid 1 Material = CONCRETE Option = Material Library MORPHOLOGY: Option = Continuous Solid END END SOLID MODELS: HEAT TRANSFER MODEL: Option = Thermal Energy END THERMAL RADIATION MODEL: Number of Histories = 10000 Option = Monte Carlo Radiation Transfer Mode = Participating Media SCATTERING MODEL: Option = None END SPECTRAL MODEL: Option = Gray END END END END DOMAIN: ROOM Coord Frame = Coord 0 Domain Type = Fluid Location = ROOM BOUNDARY: CEALING_ROOM Side 1 Boundary Type = INTERFACE Interface Boundary = On Location = ROOM_CEILING BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = No Slip Wall END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 1. Option = Opaque END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: SLABE_ROOM Side 1 Boundary Type = INTERFACE Interface Boundary = On Location = ROOM_BASE BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = No Slip Wall END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 1. Option = Opaque END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: WALL_ROOM_1 Side 1 Boundary Type = INTERFACE Interface Boundary = On Location = ROOM_WALL_1,ROOM_WALL_2,ROOM_WALL_3,ROOM_WALL_4 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = No Slip Wall END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 1. Option = Opaque END WALL ROUGHNESS: Option = Smooth Wall END END END DOMAIN MODELS: BUOYANCY MODEL: Buoyancy Reference Temperature = 25 [C] Gravity X Component = 0 [m s^-2] Gravity Y Component = -9.81 [m s^-2] Gravity Z Component = 0 [m s^-2] Option = Buoyant BUOYANCY REFERENCE LOCATION: Option = Automatic END END DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END REFERENCE PRESSURE: Reference Pressure = 1 [atm] END END FLUID DEFINITION: Fluid 1 Material = Air at 25 C Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID MODELS: COMBUSTION MODEL: Option = None END HEAT TRANSFER MODEL: Option = Thermal Energy END THERMAL RADIATION MODEL: Option = Discrete Transfer Radiation Transfer Mode = Participating Media SCATTERING MODEL: Option = None END SPECTRAL MODEL: Option = Gray END END TURBULENCE MODEL: Option = k epsilon BUOYANCY TURBULENCE: Option = None END END TURBULENT WALL FUNCTIONS: Option = Scalable END END END DOMAIN: SLABE Coord Frame = Coord 0 Domain Type = Solid Location = SLABE BOUNDARY: ADIABATIC_WALL Boundary Type = WALL Create Other Side = Off Interface Boundary = Off Location = SLABE_SIDE_WALLS,SLABE_SOIL BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 0.8 Option = Opaque END END END BOUNDARY: SLABE_ROOM Side 2 Boundary Type = INTERFACE Interface Boundary = On Location = SLABE_ROOM BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 0.8 Option = Opaque END END END BOUNDARY: SLABE_WALL Side 1 Boundary Type = INTERFACE Interface Boundary = On Location = SLABE_WALL BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 1. Option = Opaque END END END DOMAIN MODELS: DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END END SOLID DEFINITION: Solid 1 Material = CONCRETE Option = Material Library MORPHOLOGY: Option = Continuous Solid END END SOLID MODELS: HEAT TRANSFER MODEL: Option = Thermal Energy END THERMAL RADIATION MODEL: Number of Histories = 10000 Option = Monte Carlo Radiation Transfer Mode = Participating Media SCATTERING MODEL: Option = None END SPECTRAL MODEL: Option = Gray END END END END DOMAIN: WALL Coord Frame = Coord 0 Domain Type = Solid Location = WALL BOUNDARY: CEALING_WALL Side 2 Boundary Type = INTERFACE Interface Boundary = On Location = WALL_CEILING BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END END END BOUNDARY: EAST_WALL Boundary Type = WALL Create Other Side = Off Interface Boundary = Off Location = WALL_CAVITY_1 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END END END BOUNDARY: North Wall Boundary Type = WALL Create Other Side = Off Interface Boundary = Off Location = WALL_CAVITY_2 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END END END BOUNDARY: SLABE_WALL Side 2 Boundary Type = INTERFACE Interface Boundary = On Location = WALL_SLABE BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END END END BOUNDARY: South Wall Boundary Type = WALL Create Other Side = Off Interface Boundary = Off Location = WALL_CAVITY_4 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END END END BOUNDARY: WALL_ROOM_1 Side 2 Boundary Type = INTERFACE Interface Boundary = On Location = WALL_ROOM_1,WALL_ROOM_2,WALL_ROOM_3,WALL_ROOM_4 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END END END BOUNDARY: West_Wall Boundary Type = WALL Create Other Side = Off Interface Boundary = Off Location = WALL_CAVITY_3 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END END END DOMAIN MODELS: DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END END INITIALISATION: Option = Automatic INITIAL CONDITIONS: TEMPERATURE: Option = Automatic with Value Temperature = 273 [K] END END END SOLID DEFINITION: Solid 1 Material = Brick Common Option = Material Library MORPHOLOGY: Option = Continuous Solid END END SOLID MODELS: HEAT TRANSFER MODEL: Option = Thermal Energy END THERMAL RADIATION MODEL: Option = None END END END INITIALISATION: Option = Automatic INITIAL CONDITIONS: Velocity Type = Cartesian CARTESIAN VELOCITY COMPONENTS: Option = Automatic with Value U = 0 [m s^-1] V = 0 [m s^-1] W = 0 [m s^-1] END RADIATION INTENSITY: Option = Automatic END STATIC PRESSURE: Option = Automatic with Value Relative Pressure = 0 [Pa] END TEMPERATURE: Option = Automatic with Value Temperature = 298 [K] END TURBULENCE INITIAL CONDITIONS: Option = Medium Intensity and Eddy Viscosity Ratio END END END OUTPUT CONTROL: MONITOR OBJECTS: MONITOR BALANCES: Option = Full END MONITOR FORCES: Option = Full END MONITOR PARTICLES: Option = Full END MONITOR RESIDUALS: Option = Full END MONITOR TOTALS: Option = Full END END RESULTS: File Compression Level = Default Option = Standard END TRANSIENT RESULTS: Transient Results 1 File Compression Level = Default Option = Standard OUTPUT FREQUENCY: Option = Time Interval Time Interval = 1000 [s] END END END SOLUTION UNITS: Angle Units = [rad] Length Units = [m] Mass Units = [kg] Solid Angle Units = [sr] Temperature Units = [K] Time Units = [s] END SOLVER CONTROL: Turbulence Numerics = High Resolution ADVECTION SCHEME: Option = High Resolution END CONVERGENCE CONTROL: Maximum Number of Coefficient Loops = 5 Minimum Number of Coefficient Loops = 1 Timescale Control = Coefficient Loops END CONVERGENCE CRITERIA: Residual Target = 0.00001 Residual Type = RMS END TRANSIENT SCHEME: Option = Second Order Backward Euler TIMESTEP INITIALISATION: Option = Automatic END END END END ################################################# but if we apply Ra = constant in expression it will run fine but that is not a actual case Thank you sir |
Hello sir,
Here i attached CEL Expression And Variables CEL EXPRESSION LIBRARY: CEL: &replace EXPRESSIONS: Avg Top Temp = areaAve(T)@CEILING_ATM Differe = Avg Top Temp -Dry Bulb Temp Dry Bulb Temp = DRY BULB TEMP(t) Global Radiation = GLOBAL RADIATION ON CEALING(t) Gr = (g*beta*(Avg Top Temp -Dry Bulb Temp )*L^3)/(visc^2) Gr1 = if(Gr <= 0,-1*Gr,Gr) K = 0.026 [W m^-1 K^-1] L = 1.6 [m] Nu = 0.5*(Ra1^0.25) Pr = 0.71375 Ra = Gr1*Pr Ra1 = if(Ra <= 0,-1*Ra,Ra) h = (Nu*K)/L q con = h*(Differe) q inc = 0.2*Global Radiation q net = abs(q inc - q con) visc = 0.00001545 [m^2 s^-1] END END END USER FUNCTION LIBRARY: CEL: &replace FUNCTION: DRY BULB TEMP Argument Units = [s] Option = Interpolation Profile Function = Off Result Units = [K] INTERPOLATION DATA: Data Pairs = 0,296.6,3600,296.6,7200,296.2,10800,295.4,14400,29 4.7,18000,293.9,21600,293.4,25200,294,28800,295.4, 32400,297.2,36000,299.3,39600,301.2,43200,303,4680 0,304.4,50400,305.6,54000,306.4,57600,306.8,61200, 306.2,64800,305,68400,303,72000,300.9,75600,299,79 200,297.9,82800,297.2,86400,297 Extend Max = No Extend Min = No Option = One Dimensional END END END END LIBRARY: CEL: &replace FUNCTION: GLOBAL RADIATION ON CEALING Argument Units = [s] Option = Interpolation Profile Function = Off Result Units = [W m^-2] INTERPOLATION DATA: Data Pairs = 0,0,3600,0,7200,0,10800,0,14400,0,18000,0,21600,0, 25200,22.7,28800,142.6391808,32400,312.392491,3600 0,536.6750084,39600,777.0714132,43200,878.2510173, 46800,930.2914616,50400,944.7675523,54000,812.9697 022,57600,562.9522782,61200,303.4616159,64800,94.1 5321058,68400,0,72000,0,75600,0,79200,0,82800,0,86 400,0 Extend Max = No Extend Min = No Option = One Dimensional END END END END LIBRARY: CEL: &replace FUNCTION: GLOBAL RADIATION ON EAST Argument Units = [s] Option = Interpolation Profile Function = Off Result Units = [W m^-2] INTERPOLATION DATA: Data Pairs = 0,0,3600,0,7200,0,10800,0,14400,0,18000,0,21600,0, 25200,26.25062504,28800,134.1803446,32400,613.6529 541,36000,709.9563769,39600,749.3350016,43200,585. 9693094,46800,382.3657474,50400,181.0886787,54000, 168.5290584,57600,136.8601059,61200,91.50844287,64 800,37.10802755,68400,0,72000,0,75600,0,79200,0,82 800,0,86400,0 Extend Max = No Extend Min = No Option = One Dimensional END END END END LIBRARY: CEL: &replace FUNCTION: GLOBAL RADIATION ON NORTH Argument Units = [s] Option = Interpolation Profile Function = Off Result Units = [W m^-2] INTERPOLATION DATA: Data Pairs = 0,0,3600,0,7200,0,10800,0,14400,0,18000,0,21600,0, 25200,16.64501043,28800,127.7400598,32400,117.7366 103,36000,159.4982633,39600,193.2113825,43200,199. 1427246,46800,191.4867793,50400,181.0886787,54000, 168.5290584,57600,136.8601059,61200,91.50844287,64 800,37.10802755,68400,0,72000,0,75600,0,79200,0,82 800,0,86400,0 Extend Max = No Extend Min = No Option = One Dimensional END END END END LIBRARY: CEL: &replace FUNCTION: GLOBAL RADIATION ON SOUTH Argument Units = [s] Option = Interpolation Profile Function = Off Result Units = [W m^-2] INTERPOLATION DATA: Data Pairs = 0,0,3600,0,7200,0,10800,0,14400,0,18000,0,21600,0, 25200,15.02644988,28800,19.11653453,32400,104.8584 968,36000,178.380534,39600,253.6895245,43200,287.9 649814,46800,299.1082256,50400,296.3887936,54000,2 62.4819492,57600,192.7043193,61200,110.7620703,648 00,38.61686584,68400,0,72000,0,75600,0,79200,0,828 00,0,86400,0 Extend Max = No Extend Min = No Option = One Dimensional END END END END LIBRARY: CEL: &replace FUNCTION: GLOBAL RADIATION ON WEST Argument Units = [s] Option = Interpolation Profile Function = Off Result Units = [W m^-2] INTERPOLATION DATA: Data Pairs = 0,0,3600,0,7200,0,10800,0,14400,0,18000,0,21600,0, 25200,15.02644988,28800,19.11653453,32400,104.8584 968,36000,159.4982633,39600,193.2113825,43200,199. 1427246,46800,191.4867793,50400,206.4635465,54000, 382.6542143,57600,424.2491392,61200,306.7672572,64 800,112.6389917,68400,0,72000,0,75600,0,79200,0,82 800,0,86400,0 Extend Max = No Extend Min = No Option = One Dimensional END END END END THANK YOU SIR |
I see your functions like "GLOBAL RADIATION ON SOUTH" have spaces in the numbers - like "828 00". This will cause problems in CFX, but this maight be just an artefact of copying it into the forum.
If that is not the problem I would go through your CEL one function at a time. Replace a function with a constant value and see if it works. Then you should be able to find the function which is causing the problem. |
Hello Sir,
Thank you for your reply.i will check as you suggested by replacing function with constant Thank you sir Sunil Patil |
PS: Well, I think I figured out. I got this error when I tried to monitor a force. I fixed it by cancling the user-defined monitor. |
THERMX error
Hello liucheng860212,
ya i also did the same,i removed out put monitor of ceiling temperature it worked fine. Thank you Sunil patil |
