Problem using Central differencing scheme with LES in CFX
Old   August 2, 2013, 07:39
Default Problem using Central differencing scheme with LES in CFX
Karthik
selvam2487 is on a distinguished road
Send a message via Skype™ to selvam2487
Dear Friends,
I am investigating fluid mixing in T junction flows using LES in ANSYS CFX. I have a problem with my simulation. I wanted to do my LES in central differencing scheme. But the solution I get is very unrealistic. These are my input flow conditions
Hot inlet:Temperature - 393 K,mass flow - 400 g/s
Cold inlet:Temperature - 298 K,mass flow - 100 g/s
But the temperature range is 200 K - 450 K in the output result file. I have checked almost everything that I know of to find the source of error. But still central differencing scheme does not work for my LES. The mesh quality parameters are as follows:
Min. Angle - 30°
Aspect ration - 10
volume change - 5
I have attached some pictures which show the inputs that I gave for my simulations in the dropbox link below. Kindly have a look at it and please help me to correct my mistake. Thank you for your help in advance.
https://www.dropbox.com/sh/fai92g0od...f/MTv1KYjnWp#/
P.S: Even if I use Bounded Central difference scheme, the unrealistic temperatures remain the same.
Regards,
Karthick Selvam.
selvam2487 is offline   Reply With Quote
Old   August 2, 2013, 08:23
What happens when you run a well bounded scheme like high resolution or upwinding?
Old   August 2, 2013, 09:01
Default Problem with Central differencing scheme in LES in CFX
Karthik
Dear Glenn,
When using upwind scheme, the temperature is within limits and the results are ok. The same goes for high resolution scheme too. The results are physical. But when performing the LES using central differencing scheme, the results become very unphysical.
Regards,
Karthick
Old   August 2, 2013, 09:13
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Does your mesh contain non-Hexahedral cells?
With all commercial CFD solvers I used so far, central differences for LES could only be used for hexahedral meshes.
With tet or poly cells, the results were always unrealistic.
flotus1 is offline   Reply With Quote
Old   August 3, 2013, 06:01
OK, so it looks like you have a boundedness problem. Alex's comment is important - mesh quality is vital.
But also have a look at your results using the bounded schemes like high resolution. If the results are reasonable (ie turbulence spectrums look OK, global results are reasonable) then you can consider using it.
Old   August 3, 2013, 09:33
Karthik
Dear Glenn and Alex,
I am using a hexahedral mesh for my LES. I have attached the pictures of mesh type and mesh quality parameters. I have searched for the mistakes that you mentioned in my mesh (like hexahedral elements, mesh quality etc.) and I found that they are within reasonable limits. I am also attaching the link for the blocking of my T junction so that you can have a look at my mesh quality and detect any obvious or other mistakes that I did not look carefully into.
https://www.dropbox.com/s/szf9j5r4n8...%20blocking.7z
Thank you.
Regards,
Karthick
Old   August 4, 2013, 07:31
"Reasonable" limits for some simulations might not be reasonable for this application. I suspect you will find this case is much more sensitivie to mesh quality than normal, so your "reasonable limits" are not applicable.
I woudl recommend you do a study of mesh quality versus simulation quality. Generate a dummy geometry with similar physics which is easy to mesh with high quality elements (preferably perfectly orthogonal hexes) Then produce a series of meshes, starting from perfectly orthogonal/aspect ratio=1 and stepping down in mesh quality by deliberately distorting the mesh. I bet if you do the same simulation on this series of meshes that it runs fine on the perfectly orthogonal/aspect ratio=1 mesh and you will fine boundedness errors start increasing as the mesh quality decreases. And I bet you will find the error is unacceptable well before the "reasonable limits" you have quoted.
This test will take a bit of time to set up and run, but it will be very valuable for your simulation and you will know the mesh quality you need and I bet you will learn a lot about CFD in the process. Sounds worthwhile to me.
Old   August 4, 2013, 07:55
Default Mesh quality
Karthik
Dear Glenn,
Thanks for the information. I will do the mesh quality study which you have mentioned and will observe what happens with decreasing quality of the mesh.
Regards,
Karthick
Old   April 11, 2016, 13:15
Joe
enayath is on a distinguished road
Any update selvam2487?
Could you figure it out? what was the problem?
enayath is offline   Reply With Quote
discretisation, t junction
LES of Non-Premixed Combustion in CFX?? Manu CFX 5 February 25, 2008 16:34
?to implement gamma differencing scheme Gonski Main CFD Forum 15 January 28, 2007 17:00
problem about numerical scheme in LES. libin Main CFD Forum 4 July 1, 2004 04:32
Central Differencing Scheme in Fluent alice FLUENT 2 March 21, 2004 07:30
Central differencing scheme alice FLUENT 1 March 11, 2004 19:07
