March 27, 2013, 12:57 |
CFX and Transient Thermal Results
Bhavik
Rep Power: 14 |
I used transient thermal and CFX with same setup but I am getting differences in the results. So can anyone guide me regarding this. Actually I want to use the thermal results in Transient structural to determine thermal stresses.
March 27, 2013, 16:57 |
Rep Power: 143 |
March 27, 2013, 22:44 |
Bhavik
Rep Power: 14 |
No I am not getting errors in the results but the results are not matching.
March 27, 2013, 22:57 |
Rep Power: 143 |
So, you have an inaccuracy between the ANSYS and CFX simulations, right? Then the FAQ I quoted is the place to start.
March 28, 2013, 02:47 |
Thiagu
Rep Power: 13 |
# provide the CFX case setup / result details clearly
# how much the deviation is, which parameter is deviating |
March 28, 2013, 23:31 |
Bhavik
Rep Power: 14 |
I have attached the CFX setup, I am getting the value of max temp different in both cases.
3.jpg Capture 2.jpg Capture.jpg s.jpg |
March 29, 2013, 14:04 |
Erik
Rep Power: 23 |
Is everything the same on both simulations, initial conditions, material properties, geometry, etc?
Have you reached a grid independant, and time step independant solution with both simulations. How did you pick your timesteps? Are you converging each timestep in CFX, and if so to what residual level? Are you sure you put in the same boundary conditions in mechanical, the timesteps can be a bit tricky sometimes, especially when entering a function for multiple time steps. |
Time average results in Transient CFX Simulation | BalanceChen | CFX | 32 | September 30, 2021 13:59 |
FSI Transient Thermal Analysis | Abduri | CFX | 1 | January 1, 2017 22:54 |
Problem: Very long "write" time (~2h-3h) for results and transient results | Shawn_A | CFX | 16 | April 12, 2016 20:49 |
export transient CFX results to tecplot | n.r. | CFX | 0 | October 26, 2007 06:46 |
CFX cylinder or sphere benchmark results | Mel | CFX | 1 | August 8, 2005 18:47 |
