April 14, 2013, 05:48 |
error
Govindaraju
Rep Power: 17 |
Dear friends
I have given pulsatile pressure as input and pulsatile velocity as output. The solution runs normally until 90 iteration. After it comes out with the following error. Kindly correct if I made a mistake Thank you Govind +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Floating point exception: Overflow | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine FPX: C_FPX_HANDLER | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. +--------------------------------------------------------------------+ | Warning! | | | | After waiting for 60 seconds, 1 solver manager process(es) appear | | not to have noticed that this run has ended. You may get errors | | removing some files if they are still open in the solver manager. | +--------------------------------------------------------------------+ This run of the ANSYS CFX Solver has finished. |
April 14, 2013, 07:18 |
Rep Power: 143 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
[OpenFOAM] Saving ParaFoam views and case | sail | ParaView | 9 | November 25, 2011 15:46 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
