April 16, 2013, 03:36 |
Stage Interface errors & requirements
Jens H.
Rep Power: 13 |
Hello everybody,
first: Thank you very much for this forum and the FAQ! Helped me a lot! But now i have a problem and don't find the problem.. I want to calculate a cavity chamber as rotating domain with a inflow from a non-rotating domain. So i modeled the two domains, the chamber and the inflow, and connected them with a stage interface. The chamber has a 120° symmetry and i modeled the inflow as a 10° part. The calculation is always hardly diverging at the stage interface. I can bring it to converge if i use a frozen rotor. But surely then i only have a local inflow. So my questions are: 1) Are there special requirements for the axial and circumferential velocity (for stage interfaces)? Because i only have a very small axial flow through the interface compared to the circumferential velocity.. 2) I found some local backflows over the interface.. How stable is a stage interface with this kind of initial problems? I hope you can give me some advice from your experience with the stage interfaces about its stability and special requirements.. Thanks a lot |
Display Modes | |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
