CFX Post
Old   April 13, 2013, 23:51
Default CFX Post
AJ Hunter
ajhunte is on a distinguished road
I have a component that I entered a volumetric Heat Rate (W/m3) into. I am trying to find the correct calculator in the CFX-Post to show me the total Heat rate in the component (Total W). I am not seeing this as one of the possible variables.
Am I missing something?
ajhunte is offline   Reply With Quote
Old   April 14, 2013, 07:12
Source terms are not output to the results file. To view them, generate an additional variable defined by a CEL expression, and use the same CEL expression you used to generate the source term. Then this additional variable will be visible in post processing.
Old   April 14, 2013, 09:41
AJ Hunter
I am very new to ANSYS. Could you elaborate a little more on how to do this. I can create an Additional Variable and give it the value [W]. Then what?
Old   April 14, 2013, 18:30
The CFX tutorials describe how to set up additional variables.
How to get reynolds stress values in POST CFX syler3321 CFX 6 January 1, 2017 07:54
CFX post legend modification mactech001 CFX 3 December 25, 2011 22:12
CFX post - graph kmgraju CFX 0 July 22, 2010 11:59
Chart Generation in CFX Post Vadim Baines-Jones CFX 2 August 28, 2007 09:14
Tecplot for CFX post processing pantangi goud CFX 2 August 24, 2005 16:42
