problem with cfx expressions
Old   April 22, 2013, 16:15
Default problem with cfx expressions
Talles Caio
TallesC is on a distinguished road
personnel must enter the equation in the cfx expressions:
Q = stefan*0.7139*(((1114.15^4)[K^4] ) - (Ts^4)[K^4] ) The Stefan-Boltzmann Law
This term is used to heat the pipe, Ts is the surface temperature of geometry in my case is a pipe, the question is how should I call Ts in the expressions cfx??
TallesC is offline   Reply With Quote
Old   April 22, 2013, 18:19
If you are applying this to a surface then simply use T. That is the local surface temperature.
Old   April 22, 2013, 20:14
Talles Caio
are you sure? I thought the variable T is the temperature at each node of the mesh, not only the surface ...
Old   April 22, 2013, 20:15
It might be in this case, good point. If the small difference is important to you then I would do a quick check case to test exactly how this is done.
Old   April 22, 2013, 21:38
Talles Caio
I found this explication in manual cfx:
This is the hybrid temperature field at a wall boundary condition. For Fixed Temperature walls, the wall temperature is the specified value Tw. For all other heat transfer boundary conditions, the wall temperature is backed out from turbulent wall functions when running a turbulent flow model. For laminar flow modelling the wall temperature is just the local fluid temperature at the vertex adjacent to the wall.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
CFX Casting problem: Can it be done all in one? jfasl CFX 1 September 14, 2010 03:14
Cel expressions for trasient problem Jervds CFX 0 March 4, 2008 10:03
Fan Modelling Problem in CFX Jenny CFX 8 September 11, 2007 13:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
