What does this message mean?
Old   April 26, 2013, 07:16
Default What does this message mean?
Prashant Kumar Singh
pks126 is on a distinguished road
Dear All
I am doing inflow distortion analysis in CFX for single stage axial flow fan.
While running following is showing in between iteration,
what is its significance?
****** Notice ****** |
| A wall has been placed at portion(s) of an INLET |
| boundary condition (at 6.9% of the faces, 4.3% of the area) |
| to prevent fluid from flowing out of the domain. |
| The boundary condition name is: Inlet. |
| The fluid name is: Air Ideal Gas. |
| If this situation persists, consider switching |
| to an Opening type boundary condition instead. |
thanks
pks126 is offline   Reply With Quote
Old   April 26, 2013, 07:21
It means exactly what it says: you have back flow at your inlet which the solver artificially stopped. This is sometimes not a problem, but often it is and it certainly makes convergence harder. Move your inlets further upstream to get it out of the recirculation.
Old   April 26, 2013, 09:58
Thanks Sir,
Yes I am getting problem in convergence. Can i say that back flow at the inlet may be due to compressor stall or surge?
Old   April 27, 2013, 06:50
There is an FAQ on this as well (the concept is just as applicable to inlets as outlets).
No, this is unlikely to be related to stall or surge. Don't forget an inlet is upstream of the rotor .
ShockTube, error message. foamer OpenFOAM 8 January 30, 2013 04:31
single directional message transmit in parallel model su_junwei OpenFOAM Programming & Development 1 December 17, 2009 07:00
Error message in CFX-10 CFDworker CFX 2 October 12, 2007 07:23
how to avoid reverse flow message Amit Mahulkar FLUENT 0 April 20, 2006 00:45
Error Message on es-ice [BUG] Wendy Tjia Siemens 0 February 10, 2005 08:40
