mass imbalance at the inlet, interface, outlet
Like Tree1Likes
  • 1 Post By JuPa
Old   October 30, 2014, 11:16
Red face mass imbalance at the inlet, interface, outlet
Sharon Wilcox
CFDturbomachinery is on a distinguished road
In my turbine simulation, there is some mass imbalance between the inlet, interface, and outlet. I have two domain: stator and rotor, connected by an interface. When i checked the mass flow through the interface, there was a huge difference (say 60 lps at inlet, 3 lps at the interface, and 58 lps at outlet). why is there very little mass flow through the interface, which should exactly the same 60 lps at all locations?
Thanks much.
CFDturbomachinery is offline   Reply With Quote
Old   October 30, 2014, 11:20
JuPa's Avatar
Mr CFD
JuPa is on a distinguished road
I don't have turbo machinery experience so I'll talk in broad terms. The first and obvious question is have you properly defined your setup? Do the tutorials simulate turbo machinery problems the same way you are?
Secondly have your residuals reduced sufficiently?
Lastly, are your inlets and outlets far away from where the action occurs?
CFDturbomachinery likes this.
JuPa is offline   Reply With Quote
Old   October 30, 2014, 11:54
Sharon Wilcox
Thanks RicochetJ,. yes i checked the tutorials and did the setup in the same way as in tutorials...inlets and outlets are far way though..my redisudals reduced to 10-4 but not less than that...
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 09:49
Radiation interface hinca CFX 15 January 26, 2014 17:11
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
