simplified paralle tube bundle simulation (porous domain)
Old   May 4, 2013, 13:07
Default simplified paralle tube bundle simulation (porous domain)
Benny
Benfa is on a distinguished road
I tried to simulate the flow of air trough multiple parallel tubes. The first simulation with resolving each tube is running fine and the results are in agreement with expectations. But the simulation is for sure much too detailed and needs a lot of mesh points. therefore i tried to simulate the tube bundle using a porous domain (setting a porosity and direction). there are three domains, each a cylinder. the first is a fluid domain that contains the inlet. the second is the porous domain and the third a fluid domain that has the outlet. the interfaces between the domains are set. I observe that the flow trough the porous domain looks ok (expected average velocity) til the last nodes in the porous domain where the flow exits into the fluid domain. there is a big increase in velocity and the velocity profile looks wired. I tried a lot and could break it down that this effect is increased while decreasing the porosity. Has anybody observed this too? Do I need to set a specific expert parameter? I think this should be a standard application for a porous domain.
Thanks
Benfa is offline   Reply With Quote
Old   May 5, 2013, 08:01
Please post an image of what you are seeing.
Chemical Reaction in Porous Domain cibo CFX 7 October 21, 2019 07:55
How to specify Laminar zone for Porous domain vemps OpenFOAM Running, Solving & CFD 1 October 29, 2012 14:42
CFX domain comparison Kiat110616 CFX 4 April 3, 2011 22:43
porous domain problem sudhakar CFX 6 November 29, 2006 09:48
Help on simulation domain Derek Jing Main CFD Forum 3 June 6, 2002 20:21
