Home > Forums > CFX
Back flow in axial comperssor
Old   May 5, 2013, 17:28
Default Back flow in axial comperssor
eslam nagy
eslamnagy is on a distinguished road
Send a message via MSN to eslamnagy Send a message via Yahoo to eslamnagy Send a message via Skype™ to eslamnagy
DEAR SIRS
I NEED TO KNOW THE BEST BOUNDARY CONDITIONS USED IN MODELING OF AXIAL FLOW COMPRESSOR IN ANSYS CFX .
IF I USED INLET PRESSURE 1 Pa AND MASS FLOW RATE AT OUTLET =20KG/S
THE SOLUTION NOT CONVERGE ???I DO NOT KNOW WHY ??
THE PRESSURE RATIO =2.105
eslamnagy is offline   Reply With Quote
Old   May 5, 2013, 18:52
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
FAQ: http://www.cfd-online.com/Wiki/Ansys...gence_criteria
And also read the best practises guide for turbomachinery in the CFX documentation.
Old   May 26, 2013, 08:36
eslam nagy
i mean the best type of boundary condition (pressure inlet or mass flow rate inlet also pressure outlet or mass flow rate outlet)
Old   May 26, 2013, 09:00
Usually a mass flow inlet with a pressure outlet is best.
But this is all discussed in the documentation. You really should read it so you know the answers to these questions yourself.
Old   May 27, 2013, 06:42
Tushar Chourushi
Tushar@cfd is on a distinguished road
Originally Posted by eslamnagy View Post
DEAR SIRS
Boundary conditions seems to be OK...
You can also give the following boundary conditions:
Inlet: massflowrate @ 20 kg/s
Outlet: Static Pressure
Try to put Y+ value correctly as found by the formula.
Apply SST turbulence model, if you are not having much experience in CFD.
I hope this will improve your convergence.
Tushar@cfd is offline   Reply With Quote
Thread Tools
Trackbacks are On
Axial velocity problem in 2D axisymmetrical flow mozkan26 FLUENT 19 April 28, 2013 13:06
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 5 March 2, 2013 15:02
Flow meter Design CD adapco Group Marketing CD-adapco 3 June 21, 2011 08:33
Surface streamlines on axial flow fans Jennifer CFX 2 February 17, 2009 15:50
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 2, 1999 23:18
