May 6, 2013, 07:02 |
Euler Lagrange Convergence Tips
Pradeep
I am doing spray simulation in a pipe. Where nozzle is placed coaxial to the pipe with the help of an elbow. The pipe is approx. 3m long and
The bc of sim are as follows.. At inlet velocity profile is used with a static temp of 350 C (Approx 4.65 bars) to account for secondary flow inside the testrig At outlet Avg static pr. of 4.63 bar is specified. For particles Injection parameters are spec acc to lisa computations. Breakup length approx. 1mm Radius at breakup 0.7mm Vel Magnitude 121 m/s Injection type: Discrete Diameter distribution. (Approx Rosin Rammler Dia 51 micron and spread approx 3.75) No. of Rep Particles: 100000 Unfortunately I am not able to get converged results..After approx 100 iterations solver diverges... My particle solver setup is as follows.. PARTICLE CONTROL: PARTICLE INTEGRATION: First Iteration for Particle Calculation = 300 Iteration Frequency = 10 Maximum Particle Integration Time Step = 1.0E10 [s] Number of Integration Steps per Element = 100 Option = Forward Euler END PARTICLE SOURCE SMOOTHING: Option = Smooth END PARTICLE TERMINATION CONTROL: Maximum Number of Integration Steps = 100000 Maximum Tracking Distance = 2 [m] Maximum Tracking Time = 10 [s] END PARTICLE UNDER RELAXATION FACTORS: Energy Under Relaxation Factor = 0.5 Energy Under Relaxation Factor for First Particle Integration = 0.5 Mass Under Relaxation Factor = 0.5 Mass Under Relaxation Factor for First Particle Integration = 0.5 Velocity Under Relaxation Factor = 0.5 Velocity Under Relaxation Factor for First Particle Integration = 0.5 END VERTEX VARIABLE SMOOTHING: Option = Smooth END END VELOCITY PRESSURE COUPLING: Rhie Chow Option = High Resolution END END I have tried many trials by changing relaxation factors up to 0.1 for particles and Iteration frequency up to 25 but still no success. Also one thing i noticed was.. When I deactivate turbulent dispersion of partilces I get a good convergence. When I activate turbulent dispersion my simulation keeps on diverging. Any tips would be of great help. |
May 6, 2013, 07:21 |
Rep Power: 143 |
Are you sure you have your reference pressure and boundary pressures set correctly? This simulation sounds like it needs a reference pressure of 4.63 bar, an inlet of 0.02 bar and outlet of 0 bar.
Aer you sure you need to model this as a particle tracking model? If you want to model breakup then I guess you have to. But if the Eualrian model is applicable it can be much easier to use and run. Forget your previous SIMPLE solver experience and stop fiddling with under relaxation factors. It is extremely rare that you need to adjust these in CFX. If you are not getting convergence it is not due to tunder relaxation factors but a more fundamental problem with your simulation. Likewise for Rhie Chow - leave this at default. My recommendation is to make sure this converges without the spray on first. In fact you should do a sensitivity analysis on this basic flow first to ensure that you are modellign the single phase flow OK before proceeding. One that is done turn the spray on, initially with just a few particles and no spray break up or turbulent dispersion. Then add the physics one bit at a time - first the spray break up, then the turbulent dispersion, then anything else. Make sure each bit is working correctly before proceeding. And there is comments in the CFX documentation about convergence with turbulent dispersion - I recommend you read it. It will tell you why you are not converging with it. |
May 6, 2013, 08:15 |
Pradeep
Dear ghorrocks,
Continuousphase is working fine..My Inlet bc is Velocity magnitude (Which uses a velocity profile). This velocity profile was obtained by a transient sim of the entire testrig. At Exit I have pressure of 4.63bar.. And ref pressure of 0 bars. Which gives me 4.65 bars of pressure at inlet Which fairly match with experiments. The only problem I face is with particles..When I inject many particles I face this problem of convergence..(above 10000 particles). Thank you verymuch for the reply. I will take your advice and rebuild the simulation.. Regards, Pradeep |
cfx, euler-lagrange, spray |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 23:03 |
tips to speedup the convergence of CHT problem with gravity | derisala | FLUENT | 1 | February 24, 2011 03:28 |
convergence of DG for Euler equations | Shyam | Main CFD Forum | 2 | February 7, 2009 01:48 |
convergence of Euler Equations with WENO | Shyam | Main CFD Forum | 0 | June 1, 2007 01:47 |
Convergence tips | John | CFX | 3 | August 28, 2005 02:15 |
