-   -   ducted fan setup. help me! (http://www.cfd-online.com/Forums/cfx/117483-ducted-fan-setup-help-me.html)
kr2552 May 9, 2013 04:10
First of all i am sorry that i'm not good at english
i made two geometry (stator, rotor) then i used turbo grid and made meshes
in cfx setup i use frozen rotor and ratio 1
but in result looks like discconection between rotor and stator
i check it by stream line
in rotor stream line moving rotational direction but in stator in just go down not affected by rotor
how can i solve it....... can u explain easily? i tried to read tutorial but i can not find proper example
hmasenger May 9, 2013 04:34
Did you well defined connection constraint before meshing the domains? Take a look at that you need a connection mesh sizing
ghorrocks May 9, 2013 06:25
Can you post an image or what you are seeing?
Also, are you drawing streamlines using Velocity or Velocity in Stationary Frame?
