May 15, 2013, 02:36 |
Two initialisation files for simulation
Dear Friends,
I am currently doing Large Eddy simulations about thermal mixing of fluids in a T junction piping system. I am interested in giving two different initialisation files to the hot and cold pipes separately. I do not know how to do it (I have given the result file of a previous simulation as an input to another simulation, but this type of giving two separate input files for the two pipe inlets is new for me). Also, is it possible to give an experimental data at the two inlets as an input for my simulation? I have uploaded the pictures for your reference. Thank you very much for your help in advance. Regards, Karthick |
May 15, 2013, 03:24 |
Rep Power: 143 |
What type of experimental conditions do you wish to apply at the inlets? A pressure or flowrate everywhere? Or a velocity field with turbulent variations in it?
I haev never tried interpolating two results onto a single result. I am not sure it is going to work. You might need fortran to do this, but try the simple approaches first. |
boundary conditions, t junction, thermal mixing |
UDF issue | MASOUD | Fluent UDF and Scheme Programming | 14 | December 6, 2012 13:39 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 10:46 |
