one face turn to be two in pre
I am simulating the flow field of a large room. There are several pipes in the room. Air flows from the large room to the outer environment through pipes.
I try to start with an easy model. First i model the room and then i direct model one pipe in the room through UG. When meshing, I creat two material bodies, one for the pipe, and the other for the big room. And i named the the inlet face of the pipe which connects the big room as IN. But when i load the mesh in the CFX-pre, I found the CFX named the IN as IN-a,IN-b. Why will that happen? Is it OK? |
This is probably because the IN surface is shared by two domains (materials) here - pipe and room. Hence a and b sides belong to the two domains meeting at your surface.
As long as both are same materials, ie air, you should be fine. OJ |
