April 26, 2013, 15:11 |
TBR Fourier Transformation Method
Rep Power: 13 |
Hello to all,
i calculate a Rotor Stator passage in TBR Profile Transformation and it works. If i try it in TBR Fourier Transformation Method it doesn't work. Error: In Analysis 'Flow Analysis 1' - Fourier Transformation 'Fourier Transformation 2': The relative velocity between the domain and the signal must not be zero. So i have to put a coordinante frame? I don't get it. Have somebody a Tutorial to Typical Transient Rotor Stator Simulation using Fourier Transformation like in Modeling Guide - 6.8.1 Case 1: Transient Rotor Stator Single Stage? In the Tutorials from the help are two examples, but only for an Inlet Disturbance Case and a Method for a Blade Flutter Case. Thx and regards Eschek |
May 2, 2013, 14:23 |
Rep Power: 13 |
Some additional informations:
I choose Transient Blade Row Model: Fourier Transformation; And i add a new item with a default name. And after that I have in Option only the two possibilites: "Rotational Flow Boundary Disturbance" and "Blade Flutter", but no "Rotor Stator" option. In the Manual "CFX-PRe User's Guide - Chapter 22.2" stands: This option can be applied only when the disturbance originates from a domain interface that uses the Transient Rotor Stator frame change/mixing model. But with this help i can not fix it. Regards Eschek |
May 16, 2013, 16:12 |
Rep Power: 13 |
to calculate the single stage in Fourier-Transformation you have to enable the Beta-Features in ANSYS 14.5 Regards |
[Gmsh] discretizer - gmshToFoam | Andyjoe | OpenFOAM Meshing & Mesh Conversion | 13 | March 14, 2012 04:35 |
De-aliased Fourier spectral method | TTY | Main CFD Forum | 0 | November 10, 2010 16:55 |
Code for most powerfull FDV Method | D.S.Nasan | Main CFD Forum | 6 | September 4, 2008 02:08 |
Fast Fourier Transformation | mstein | Main CFD Forum | 5 | May 16, 2004 11:20 |
