Home > Forums > CFX
cfx-solver local parallel causes linear solver error
Old   May 31, 2013, 02:50
Default cfx-solver local parallel causes linear solver error
m4D
m4D is on a distinguished road
Hi!
I'm modelling a turbomachine passage (includes rotor and stator) in cfx. The mesh is generated in turbogrid, and it's ok/OK there. The problem is set up in cfx-pre with the use of Turbo-mode and pretty standard. When i solve the problem using serial mode, it runs ok and converges. When i set up local parallel, it fails on the 1st iteration with finmes linear solver error. What's the problem? Does the partitioner messses smth up?
m4D is offline   Reply With Quote
Old   May 31, 2013, 06:14
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
It is rare for a simulation which runs serial to fail parallel. But you seem to have found one. Sometimes you can make it run by defining a different partitioning algorithm and making sure partition boundaries do not lie on critical parts of the flow like free surfaces or shock waves.
ghorrocks is online now   Reply With Quote
Thread Tools
Trackbacks are On
installing funkySetFields igo OpenFOAM 1 November 20, 2012 21:16
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
user defined function cfduser CFX 0 April 29, 2006 10:58
