May 7, 2018, 17:14 |
sub channel analysis
Hosam
Rep Power: 8 |
Hi ,
I'm working in nuclear reactor fluid sub channel heat transfer from fuel rods walls( heat source ,with constant heat flux) to coolant (fluid domin) sub channel with mixing vane (Solid domin), So I found some difficulties as follows: 1. make good setup to deal with solid domin inside fluid domin to make the analysis of heat transfer and flow behavior. 2. define Nusselt number. |
May 7, 2018, 17:49 |
Erik
Rep Power: 23 |
If you are using constant Heat flux at the interface, you do not need to model the solid. Just a void in the fluid domain, where you would use a heat flux boundary condition.
Check the FAQ's for HTC and Nusselt Info: https://www.cfd-online.com/Wiki/Ansy...ficient_in_CFX |
May 8, 2018, 02:53 |
Hosam
Rep Power: 8 |
[QUOTE=evcelica;691547]If you are using constant Heat flux at the interface, you do not need to model the solid. Just a void in the fluid domain, where you would use a heat flux boundary condition.
thank u for reply, heat flux BC will apply to the walls of fuel rods interface with fluid sub channel, also i.wont elaborattion about a void in fluid domin |
mixing vane analysis, sub channel |
Enabling Open Channel Flow Sub-Model in Mixture model | cod213 | FLUENT | 0 | January 10, 2017 13:40 |
ANSYS WORKBENCH Transfer result of one analysis to a new analysis as preload | ingjuanm90 | ANSYS | 0 | July 26, 2016 14:04 |
Turbulent transition in channel flow | yansheng | STAR-CCM+ | 11 | June 16, 2016 09:05 |
Meshing of a Channel with Dimples for cooling analysis | cuppigroup | CFD Freelancers | 4 | May 2, 2016 05:53 |
interFoam Micro channel | 1988 | OpenFOAM Running, Solving & CFD | 1 | January 25, 2015 13:50 |
