-   -   How to use batch mode/file and run on parallel computer (http://www.cfd-online.com/Forums/cfx/118873-how-use-batch-mode-file-run-parallel-computer.html)
Irondome June 5, 2013 14:22
Hi
I start to learn how to solve turbomachinary problem i.e solve a rotor case using the tutorial and i will have to use some batch file or mode to run this for several stages on a parallel computer. I am new to CFX and went through user guides but I end up confused :( . :confused: .. can someone help me ? :)
Thank You
ghorrocks June 5, 2013 21:41
This all explained in the documentation and demonstrated in the tutorials. If you explain what your problem is we might be able to help you.
Irondome June 14, 2013 12:06
which tutorials ? the ones which come with cfx software ?
Irondome June 14, 2013 12:16
Irondome June 14, 2013 16:46
I am currently doing project on rotor37. Using tutorials, I could use CFX to get the desired velocity contours. This was only for one stage of rotors. My professor asked me to write some script in batch file and that I will have to run on parallel computers for n number of stages. I donno how to write it or run the CFX . :o:confused:
Can you please help ?
Thank You
ghorrocks June 16, 2013 06:26
I do not know what you are asking. Are you having problems setting up for multiple blade rows or problems setting up parallel simulations or problems with batch files?
venkateshaero June 17, 2013 07:35
Thank You
please mail me venkiaero2004@gmail.com
