Setting up turbogrid for single-bladed machine (not passage with periodics!)
Old   June 6, 2013, 04:20
Default Setting up turbogrid for single-bladed machine (not passage with periodics!)
m4D
m4D is on a distinguished road
Hi!
I'm modelling a single-bladed miniature axial turbine and i want to use turbogrid for it's good mesh. The problem is, when i set up ExportPoints to 1 blade set, turbogrid throws an error "blade set count must be more than 1". Is it possible to set up turbogrid for single-bladed machine?
m4D is offline   Reply With Quote
Old   June 6, 2013, 06:18
Apparently not.
Why is your gizmo single bladed? Do you like vibrations?
Old   June 6, 2013, 07:37
m4D
Originally Posted by ghorrocks View Post
Apparently not.
The size is very small (8mm in diam) and i need max possible performance to meet required demands. Two bladed optimal design doesnt't give enough performance with so small rotor diameter. Also, rotor mass (inertia) is very small and static balancing of the rotor is done + special design of bearings - all this to minimize vibrations.
Is it possible to build manually turbogrid-like mesh using ansys-meshing? or icem-cfd? or i just should use unstructured tetra of optimal size?
Old   June 6, 2013, 07:55
I cannot see why less blades gives maximum performance. I am no turbo machinery expert so I will take your word for it.
I am also not very familiar with turbogrid so cannot say whether this is a fundamental limitation of turbogrid. It may well be, and it certainly looks like one.
In that case you will simply have to use another meshing software. ICEM is the meshing tool which gives you the greatest control over the mesh, particularly in hexa mode. But all the meshing softwares you describe will probably generate an adequate mesh.
[TGrid] Inlet passage in turbogrid. soldimix15 ANSYS Meshing & Geometry 0 September 5, 2010 11:34
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
Warning 097- AB Siemens 6 November 15, 2004 04:41
