Nodes per Core restriction?
Old   February 7, 2012, 17:01
Default Nodes per Core restriction?
Max
max3.2 is on a distinguished road
Is there a nodes per core restriction in CFX (educational)?
I have a 11mil cell mesh. If I run it on serial I get an error (something like to many integer values see below)
If I run it on more cores, it works.
I dont get that. Any ideas?
ERROR:
ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| The total number of words needed for the Real stack exceeds the m- |
| aximum supported by the flow solver: 2,147,483,647. The solver w- |
| ill continue with the stack size clipped to that value.
max3.2 is offline   Reply With Quote
Old   February 7, 2012, 21:58
Wow, that is one big simulation - 2 billion for the real stack. Then clearly having a single simulation of this size is not possible, but if you split it up into some parallel runs it is.
I was not aware that this restriction existed.
Old   February 8, 2012, 09:03
Max
I honestly don"t know whats blowing up the real stack.
Well, the cell count is high, its a duct with a wedge, hexa meshed for y+ around 1. I will be probably using it for running high volume concentration particle tracking, comparing it to experiments and DEM.
But thats just the first mesh validation for water with SST. 7Eq.
I was just wondering if that's a known issue. But since it runs parallel, it must be some limit on the single core runs.
Thanks
Max
Old   February 8, 2012, 10:03
stumpy is on a distinguished road
There is a hard limit of that many words per stack per partition. It corresponds to about 16GB I think. Running in parallel reduces the memory required per partition, so you can drop below this limit.
stumpy is offline   Reply With Quote
Old   June 8, 2013, 05:46
Vishal
vishal.indomitable is on a distinguished road
Send a message via Yahoo to vishal.indomitable
No there is no restrictions for nodes per core in CFX (educational) as I know. The same problem I am also getting. The simulation will not show any error if it is run on parallel machines.
vishal.indomitable is offline   Reply With Quote
Old   June 10, 2013, 22:26
Stumpy's post answers the question - you need to run enough partitions to get all partitions below this stack limit. This stack limit will apply for the educational version of the software as well.
solving a conduction problem in FLUENT using UDF Avin2407 Fluent UDF and Scheme Programming 1 March 13, 2015 02:02
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Performance Improvements by core locking RobertB STAR-CCM+ 7 October 22, 2010 07:59
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
