-   -   Splining turbine for periodic boundary condition (http://www.cfd-online.com/Forums/cfx/119169-splining-turbine-periodic-boundary-condition.html)
rameezib June 11, 2013 07:01
Dear friends,
I wanted to know how to spline the turbine for using periodic boundary condition, i have a rotor with 30 blades, so i know the angle will be 12 degrees, but how to get the curves on the surfaces to be splined, if my suction and pressure side curves are different ?
ghorrocks June 11, 2013 08:18
Turbogrid and bladegen where developed to make exactly this sort of thing easy. Are you using them? Or are you doing it in something else?
rameezib June 12, 2013 00:04
Bladegen has provision for only 6 types of turbomachine component, mine is an Impulse turbine, so I'm not able to use Bladegen
ghorrocks June 12, 2013 06:09
Try the geometry and meshing forum. Alternately try the forum for whatever solid modelling package you are using.
rameezib June 13, 2013 11:06
Hey thanks i have started using bladegen and its really usefull
