Home > Forums > CFX
BC export in CFX-Pre
Like Tree1Likes
  • 1 Post By mjgraf
Old   June 19, 2013, 02:36
Default BC export in CFX-Pre
TrII4d is on a distinguished road
Hi guys,
is it possible to export all the BC's from CFX-pre (e.g. Material for each Domain, Solver Control, expert parameters and s.o) to a *.csv file ?
Additionally I want, that CFX is giving me only the BC's which were changed from the "standard definition" (e.g. when i change the domain type from "fluid" to "solid)
I know that I can export all the BC's using Perl, but what I want is that CFX-pre gives me the changed BC's only ... this will be a hard work using Perl ...
my prof told me, that FLUENT is able to do that ... but he doesn't know very much about CFX ... maybe u guys have an idea?
thanks!
TrII4d is offline   Reply With Quote
Old   June 19, 2013, 03:22
Lance
Lance is on a distinguished road
So you want the settings, not only the BCs? File/Export/CCL would give you your model setup in a .ccl file, which you can open with a text editor. I dont understand why you would need a .csv file?
I dont understand your second question.
Lance is offline   Reply With Quote
Old   June 19, 2013, 03:51
Dear Lance,
thanks for ur answer.
Yeah i know about the possibility to export a *.ccl file ... after that i could use a perl script which filters the settings and BC's I need ...
but that's not exactly what I want, I try to explain it in another way:
When u create a new Domain there are standard stocks in the input fields ...what i want is, that if u change them, ANSYS export the changed values only
for example a new domain:
in the tab "basic settings" u will get the following settings:
Domain Type : Fluid Domain
Coordinate Frame : Coord 0
Reference Pressure : 0.00 [Pa]
if I change the Domain type from "Fluid Domain" to "Solid Domain" then CFX-pre should execute this information as output because I changed it ... but there should be no informations about the "coordinate frame", "reference pressure" and others because I didn't change it.
hope u got my point
- thanks!
Old   June 19, 2013, 04:19
Lance
I dont see how this is possible in CFX. My suggestion would be to export the settings before you make any changes, then make the changes and export the settings again. Then compare the two files with some sort of script/program.
But you already have this information, you know the changes you apply to the domain. Or what am I missing?
Old   June 19, 2013, 04:26
yeah this could be way to do it ...
no u r right Lance ... the reason why i'm searching for such an option is that I have *.def files with a lot of domains, interfaces and so on. ...
i'm doing some DoE at the moment ... so i want to be sure that i didn't forget all the necessary changes in the new *.def file ...
if i export all the settings from the new *.def file and from my "original" definition file, i can compare the two textfiles (*.csv or *.txt or whatever) with each other ...
if i find another way i will let u know ... if someone else has an idea ... pls let me know
Old   June 19, 2013, 23:57
mjgraf is on a distinguished road
maybe cfx5dfile can help.
if you have the cfx bin folder in your path
type
cfx5dfile -h
to bring up the help.
TrII4d likes this.
mjgraf is offline   Reply With Quote
Old   June 25, 2013, 02:27
Smile that's it!
not maybe ... it helps ... thanks a lot mjgraf for that great support! ...
thread closed!
Thread Tools
Trackbacks are On
only 1 of many named selections not showing up in cfx pre mihirbhagat CFX 0 July 5, 2011 05:22
Defining a domain in CFX Pre ashtonJ CFX 1 June 13, 2011 02:34
Export CGNS with CFX 10.0 Luca CFX 1 December 29, 2010 07:09
CFX Pre - TGrid Vivek Vasudevan CFX 2 March 20, 2007 07:31
export mesh made in ICEM to cfx Morten Andersen Main CFD Forum 2 October 26, 2006 22:52
