Ansys CFX Turbogrid, Problem with blade leading edge sitting on hub at inlet |
January 15, 2014, 17:08 |
Chaithu
Rep Power: 12 |
Hi friends,
I am still learning CFX Turbogrid and have completed examples. I am given a blade profile of stator blade and when I input bladegen file, The geometry appers to be like the one in the image attached. The The leading edge of the blade is sitting on the hub and I am unable to define topology because the periodic surface to too close for O grid generation around the blade. Can anyone please help me solve this problem ? Thanks a lot |
January 20, 2014, 09:38 |
anonymous
Rep Power: 13 |
Hi friend,
I don’t know if i understand your problem the right way. Looks like the upper right control point in your picture is too close to the blade edge. You can move it by clicking at it and then enter new coordinates (axial, radial normally). Should be discussed in one of the tutorials if I remember right. Cheers! |
January 20, 2014, 19:26 |
#3 | |
Chaithu
Rep Power: 12 |
Problem solved. |
August 18, 2016, 16:59 |
Have a nice time!
Rep Power: 11 |
I have a negative volume mech...How can I solve it? Thanks
August 18, 2016, 19:36 |
Rep Power: 143 |
August 18, 2016, 19:39 |
Have a nice time!
Rep Power: 11 |
Thanks but the mesh cannot be updated sir.
August 18, 2016, 19:44 |
Rep Power: 143 |
The problem is in your mesh, so if you can't change your mesh then you are stuck.
August 18, 2016, 19:45 |
Have a nice time!
Rep Power: 11 |
You mean I have to change the mesh settings from turbogrid?
August 18, 2016, 19:54 |
#9 |
Rep Power: 143 |
Your mesh has turned inside out. CFX cannot work with a mesh like that and has no way of fixing it. You have to go back to whereever you made the mesh and fix it there.
(I am assuming that you are not using moving mesh and that the mesh was generated like this) |
August 18, 2016, 19:56 |
#10 |
Have a nice time!
Rep Power: 11 |
What mesh? the picture is for the geometry in turbogrid...I have to control points to solve the problem..If you have any idea about that tell me...Thanks
Display Modes | |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[TGrid] Inlet passage in turbogrid. | soldimix15 | ANSYS Meshing & Geometry | 0 | September 5, 2010 12:34 |
How to control the Inlet block mesh in turbogrid | Mickel | CFX | 0 | June 21, 2006 21:21 |
FSI using CFX and ANSYS | Bi Chang | CFX | 2 | May 10, 2005 05:47 |
Radius leading edge problem | Dadang | CFX | 1 | April 20, 2004 02:35 |
