Home > Forums > CFX
Reynolds and Nusselt number in DoE
Old   June 26, 2013, 14:27
Default Reynolds and Nusselt number in DoE
Costin Ruja
costinruja is on a distinguished road
Send a message via Yahoo to costinruja
Good evening,
After solving my DoE simulation (DX and CFX in workbench) i realised i also have to define as output parametres the Reynolds and Nusselt number.How can i do that in CFX-Post? I know i can see them in the solver log but i need them as output parameters in DX.
Regards,
Costin
costinruja is offline   Reply With Quote
Old   June 26, 2013, 18:38
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
You will need to manually define variables for Re and Nu. The reported Re and Nu numbers in the solver should be taken as guides only - they are not calculated based on length, fluid property and temperature scales which are much use for most engineers.
Old   June 26, 2013, 22:33
Costin Ruja
Thanks ! I'll have to check it out first thing when i get to the office.
Old   June 27, 2013, 06:14
JuPa's Avatar
Mr CFD
JuPa is on a distinguished road
Just a heads up.
Incropera and DeWitt suggest the characteristic dimension in the Nusselt number should be taken as:
Surface area divided by surface perimeter
It doesn't explain why. However I like to think it's because:
1. The Nusselt number you will be using is likely to be an average Nusselt number based on the average heat transfer coefficient of a surface. And the way you get to the average heat transfer coefficient from a local one is by integrating the local heat transfer coefficient over the entire area. So taking the characteristic length as the surface area divided by surface perimeter makes sense (to me that is!).
2. Taking the characteristic length as the surface area divided by surface perimeter adds consistency. It means you don't have to worry about which length to take as the characteristic length if you had say a triangle, square, circle or any other shape as your heat transfer surface.
I hope that helps.
JuPa is offline   Reply With Quote
Thread Tools
Trackbacks are On
Nusselt number calculation vinaykumar Main CFD Forum 5 June 21, 2011 08:39
Airfoil Average Nusselt Number calculation y2k_o__o FLUENT 6 March 3, 2011 08:37
Reynolds Number and Heat transfer Coefficient panos_metal FLUENT 0 January 7, 2011 07:37
Help with UDF - nusselt number Sammie FLUENT 0 October 24, 2007 07:10
Nusselt number in UDF Manuel FLUENT 0 November 6, 2006 08:23
