Home > Forums > CFX
How to obtain the mesh size?
Old   June 28, 2013, 03:00
Default How to obtain the mesh size?
hustxinxin is on a distinguished road
Excuse me
Is there anybody knows how to obtain the mesh size through User Fortran? I want to add a source term to the k-ω equation, and this term is a function of the maximum length of the mesh edges.
I am really appreciate your help!
hustxinxin is offline   Reply With Quote
Old   June 28, 2013, 06:09
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
Must be a strange source term....
This is difficult to define let alone code. CFX supports tet, pyramid, prism and hex meshes - are you going to code a different case for each of them? But even trickier is that the equations are solved on control volumes centred on the nodes, and these control volumes are polyhedral. Read the documentation for more detail on this. But it means the mesh you define is not the mesh it uses for solving the equations, so working out what the longest edge length on the original mesh would appear to be of little benefit.
Old   June 28, 2013, 06:43
Thanks for your kindly reply!
So, I worked out the problem with another method, that I used "Volume of Finite Volumes^0.3333" instead, and farther more, I think it's more approriate.
Thread Tools
Trackbacks are On
[ANSYS Meshing] max mesh element size ulalala ANSYS Meshing & Geometry 8 January 20, 2013 18:30
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
Guides for calculation of mesh size for combustion Luk CFX 4 March 17, 2008 03:34
How to decide the mesh size? echo CD-adapco 1 May 23, 2006 05:34
Gambit problems Althea FLUENT 21 February 6, 2001 08:05
