Pump Cavitation Analysis in ANSYS CFX
Like Tree1Likes
  • 1 Post By techCAE
Old   June 18, 2013, 14:34
Default Pump Cavitation Analysis in ANSYS CFX
techCAE's Avatar
CAE Engineer
techCAE is on a distinguished road
Following is a series of blogs introducing to the basics of the pump cavitation analysis in ANSYS CFX and to automate this process by using CEL (CFX Expression Language) and Perl script.
Pump Cavitation Analysis in CFX (Part I)
Pump Cavitation Analysis in CFX (Part II)
Pump Cavitation Analysis in CFX (Part III)
mingbn likes this.
techCAE
(Engineering Design and Analysis with Innovation)
www.techcae.com
techCAE is offline   Reply With Quote
Old   July 1, 2013, 10:54
techCAE's Avatar
CAE Engineer
Pump Cavitation Analysis in ANSYS CFX (Part IV)
http://www.techcae.com/blog/?p=316
techCAE
www.techcae.com
Old   July 2, 2013, 07:05
Default transient simulation
zhiluguo
guoqinghust is on a distinguished road
Hi, I want to simulation the cavitation phenomenon of unsteady in a centrifugal pump by using CFX, can you give me some advice?
thank you!
guoqinghust is offline   Reply With Quote
Old   July 2, 2013, 07:33
techCAE's Avatar
CAE Engineer
thank you!
Hi guoqinghust,
Please follow the tutorials as described in this thread, and do the following:
01: Start with a steady state analysis with cavitation model turned off.
02: Then start another steady state analysis with Cavitation model turned on and initialise this analysis from step 01.
03: Strart the transient analysis with cavitation model turned on and initialise this from the results of step 02.
Regards,
techCAE
www.techcae.com
Old   July 3, 2013, 04:37
zhiluguo
Hi, techCAE
thanks for your reply!
I hope to raise another question.
As the flow in the centrifugal pump (or other hydraulic) is an unsteady process when in actual operation, can i ignore the second step and in the third step of calculation with the result of the first step as the initial value when start the unsteady cavitation simulation? What's the distinction between the result of this method and yours?
I'M looking forward to your reply!
regards
Old   July 3, 2013, 04:38
zhiluguo
Originally Posted by techCAE View Post
Hi guoqinghust,
Regards,
Hi, techCAE
regards
Old   July 3, 2013, 06:37
techCAE's Avatar
CAE Engineer
Hi, techCAE
regards
Hi guoqinghus,
That could be a good learning exercise for you, (if you are at initial stages of that analysis). Please try both and then look at the difference.
techCAE
www.techcae.com
ansys, cavitation, cfx, impeller, pump
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 05:52
Compressible Flow in Ansys CFX bcheruk CFX 15 July 6, 2017 06:30
ANSYS and CFX not talking in two-way FSI? brashear CFX 6 November 25, 2012 08:13
Electronics Enclosure Analysis with CFX Simulation Engineer CFX 1 April 22, 2009 11:08
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 01:10
