-   -   Large error in Pressure Drop in pipe (http://www.cfd-online.com/Forums/cfx/120278-large-error-pressure-drop-pipe.html)
ajhunte July 3, 2013 17:39
I have a single pipe with a triangular input and output:
Picture of the geometry (basically a pipe filled with water shaped like a triangle)
https://plus.google.com/u/0/photos/1...28021247361055
When i do a hand calculation based on the width and height of the flow path and the velocity at the inlet, I get about 10 psi pressure drop that I should be getting from inlet to outlet. When I run Ansys, I get approximately 20 psi.
I have made sure that I have an inflation for the boundary layer, I have made the mesh ridiculously fine, and that I run it to 1e-5 convergence criteria. I have also confirmed with my professor that I should be getting around 10 psi (meaning that I did not make a math error when doing the hand calculation).
Any ideas why this is occurring?
ghorrocks July 3, 2013 19:14
What is the hand calculation based on? Is the hand calculation based on fully developed flow? Did you model fully developed flow in CFX? If you just modelled a constant velocity across the entire inlet the flow would develop in the simulation and have a much higher pressure drop - his could explain your error.
The mesh you show is horribly coarse. I trust that is not the mesh you used.
Is the triangle cut out of the cylinder (ie the flow is a cylinder pipe with a triangle in the middle ) or does the flow go through the triangle bit?
Also, have you looked at the FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
