Convergence + view Condensation
Old   July 8, 2013, 11:00
Default Convergence + view Condensation
Martijn Al
martijnal is on a distinguished road
I tried to find a tutorial with someting familiair to my model but I could not find it.
I'm modelling a spray condenser: Hot gasses (T=500C, 50% N2, 50% hydrocarbon vapour A) enter at the bottom. I set this fluid as my continious fluid.
A spray of droplets (10C, 100% hydrocarbon B, 0% hydrocarbon A) is used to cool the fluid and condense hydrocarbon A.
What I cannot get working is a converged solution: the solver line keeps oscilating.
What I already tried:
Larger time scale factor
Mesh refinement
No gas flow/ no spray (conclusion: spray is the one that causes the lack of convergence)
1.Can anyone give me some advice on how to let the simulation converge?
2. When looking at the post processing, I cannot find a variable that shows how much of the hydrocarbon A is condensed and through what outlet it is flowing. I can see the massfraction of the vapour of A but not the liquid component. How can I view this?
I put my ccl file online: https://www.dropbox.com/s/ydx1n8bynzmhih1/condenser.ccl
martijnal is offline   Reply With Quote
Old   July 13, 2013, 07:44
Have you seen the FAQ on this? http://www.cfd-online.com/Wiki/Ansys...gence_criteria
Finer meshes are more likely to have convergence problems than coarser meshes. This is due to the reduced dissipation in finer meshes. So you might have more luck on convergence on coarse meshes, but of course accuracy may suffer.
Are you using turbulent dispersion on the particle tracks? The documentation explains that obtaining convergence can be very difficult with this option activated.
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 10:55
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 14:20
